What transmission was used on a 70 z28
Discussion in 'Transmission & Driveline Topics' started by 1973camaro406, Apr 16, 2015.
  1. 1973camaro406
    1973camaro406 Veteran Member
    238
    Sep 8, 2006
    What transmission was used on a 70 z28? Was it the m-22 or the m-21? I always assumed it was the m-22
  2. Double J
    Double J Veteran Member
    411
    15
    Jan 23, 2008
    Michigan
    Both could've been used it just depends on what box you checked when you ordered the car.
  3. 1973camaro406
    238
    Sep 8, 2006
    So no way to tell what the original was other than a build sheet?
  4. Gary S
    24,138
    1,643
    70 Z28 could be ordered with TH400, M20, M21, or M22. The matching VIN will be on the tranny if it is the original one.
  5. 1973camaro406
    238
    Sep 8, 2006
    Interesting really
    I don't have original tranny so it's up to me lol
    I'll prolly go with 21. It seems 22's are very high in price. Thank you!
  6. Camaro-Chevelle
    Camaro-Chevelle Veteran Member Lifetime Gold Member
    227
    Sep 22, 2007
    Long Island, New York
    What is the rear differential gear ratio?
  7. Peter Wilson
    Peter Wilson Veteran Member
    577
    Nov 24, 2006
    Chance Harbour ,N.B. Canada
    rear gear ?
    I don't think the rear gear has any bearing on it being an M21 or M22 . a local 70 Z28 has the original 12 bolt 4.10 gear rear in it and an M21 , he has the GM of Canada documentation on it and it was delivered new that way . My 71 had a 3.73 gear and an M21 when new , I know of a 71 with a 10 bolt 3.73 and original M22 .
  8. Camaro-Chevelle
    227
    Sep 22, 2007
    M21 and M22s are better suited when used with 3.55 and numerically higher gears.
    The M20 Gear Ratios are:
    First 2.52, Second 1.88, Third 1.46, Fourth 1.00.
    The M21 and M22 Gear Ratios are:
    First 2.20, Second 1.64, Third 1.28, Fourth 1.00.
    Since the M21 and M22 have a higher (Numerically Lower) first gear than the M20, it will not work well with 3.07 and 3.31 gear sets.
  9. COPO
    21,212
    2,678
    The Muncie M21-M22, works best with 3.73, 4.10 lower gears.
    A M20 will work also but you will be shifting sooner thru 1-2-3 gears.
    Any Muncie (M20, M21, M22) could be ordered with the std 3.73 in the 70 Z28, and optional 4.10 rear.
  10. Camaro-Chevelle
    227
    Sep 22, 2007
    What I don't understand is a M21 being ordered with a 3.31:1 12 Bolt in a 68 L79 Malibu. I owned this car and it is all original. I also had the original window sticker. Please look at the window sticker from Bill Simoni's Chevrolet - Buick in Loudonville, Ohio. It is the fifth item down and it is marked Baltimore Window Sticker.
    http://www.chevellestuff.net/1968/misc/paperwork.htm
    Look at lines 2 and 14 on the window sticker. Line 2 shows 6M21AH for the 4 Speed Close Ratio Transmission. Line 14 shows 6G80KA for Positraction with a 3.31 gear set. You would think that the car would have been better suited with a M20.
