What wheel backspace or offset do I need?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Big Dave, Jun 19, 2014.
  1. Big Dave
    Big Dave Veteran Member
    126
    Oct 25, 2002
    Pennsylvania (Pittsburgh)
    I'm thinking about getting a set of 15x7 Cragar SS mags for my '76 LT, and maybe 235/60-15s for the rear and maybe 205/60-15s in front. The suspension is stock. What backspacing or offset would I need for the wheels?
    Thanks!
  2. fhp1556
    fhp1556 Veteran Member
    111
    Jan 30, 2013
    Highland, IN.
    Well, considering factory rims are 15x7 w/a 4 1/4" backspacing and most people run w/a minimum 235/60 R15 at all four corners, I personally wouldn't put anything smaller on my ride. I would go w/a 15x8 rear wheel and 245 or 255/60 R15 if it were me.
  3. Big Dave
    126
    Oct 25, 2002
    The factory original rally wheels are 14x7s. I'm currently running 215/70-14s but need to replace them due to their being 15 yrs old now, so I was thinking of getting the 15 inch mags. The Cragars come in 4.125 or 4.0 inch backspacing, I think. If the original 14x7s have 4.25 inch backspace, would I want the 4.125s for 15x7s?
    If I ran 15x8s on the rear, what backspace would I want? An additional 1/2 inch to cover the extra 1 inch of wheel width?
  4. wayback
    wayback Veteran Member
    1,718
    Mar 5, 2000
    Jungleland, Minnesota
  5. The Champ
    The Champ Veteran Member
    5,463
    1,090
    Sep 14, 2000
    MN
    The original tires on your 76LT were FR78x14's which were 26.5" tall.
    Your current tires are 25.9" tall.
    A 205/60/15 is only 24.7" tall and is skinnier than current your 14's are. Way too small for a Camaro.
    A 235/60/15 is 26.1" tall shorter than the OE tires, and just a bit taller than your current tires - and should work fine on all 4 corners with the 4.125" BS.
    On the rear I'd personally want to run a tire closer to the original tire height to keep my speedometer more accurate. A 245/60/15 is 26.6" tall - and that will work fine on a 15x7" rim with 4.125" BS.
  6. Big Dave
    126
    Oct 25, 2002
    Thanks, guys.
    It looks like Wheel Vintiques and US Wheel make chrome wheels that look very similar to the Cragar SS... anyone know how they compare in quality to the Cragars?
