What will it run at the Dragstrip
Discussion in 'High Performance Modifications' started by muscl car, Jun 7, 2020.
  1. muscl car
    22,879
    1,455
    Jul 8, 2001
    SoCal High Desert
    I definitely have good valvetrain components
  2. G72Zed
    G72Zed Veteran Member
    2,052
    867
    Sep 8, 2015
    I do not think he will need to spin it that high.
    Given the fact it was stated in the first post that they are "massaged AFR 195's" (even though I thought they were the 210's) either way, with the Hyd Rollers, 427 CI at 7k, it may be "able" to turn 7K, but the fact that the combo is based on the Shafiroff 427/565hp build, it peak's at 5,800 don't see this hanging on another 1,200 rpm without a good falloff or hitting the choke point.
    Also, 7K with 400# over the nose, 1.6 RR with heavy Hyd Rollers and 5/16 .080 wall PR without a stud girdle, I'd be watching this real close, seen some combo's like this, not saying they "can't" do it, but there not that happy up there.
  3. muscl car
    22,879
    1,455
    Jul 8, 2001
    SoCal High Desert
    I'm running ARP 7/16th rocker studs
    The only thing I don't like about my motor is Shafiroff spec'd the motor with a aftermarket style Hyd roller spider / Dog bone set up
  4. G72Zed
    2,052
    867
    Sep 8, 2015
    The ARP 7/16th rocker studs are not the issue themselves.
  5. biker
    biker Veteran Member
    2,441
    935
    Dec 7, 2014
    The spider/dog bone setup is pretty good. I'm not sure, but that style of lifter may be lighter than the linked ones. Many 10's of thousands of motors with that setup have been running around out there for many years, many up to 3, 4k miles without issues from the spider and dog bones. No plastic LS lifter trays to wear and fail.
  6. 1980RS
    1980RS Veteran Member
    4,691
    1,363
    Jun 17, 2006
    MN
    That setup should run easy 10's off the trailer. The drag radials will be the limiting factor so getting them to hook will be the key to the good times.
    muscl car likes this.
  7. theflash
    11,044
    36
    Feb 27, 2004
    Podunk, CT
    I doubt you'll see 7k with hyd rollers. Why didn't you go with solid?
    As far as DRs go, I ran 10.85 on MT's
  8. 1980RS
    4,691
    1,363
    Jun 17, 2006
    MN
    So when's the first track day with the new engine?
  9. muscl car
    22,879
    1,455
    Jul 8, 2001
    SoCal High Desert
    Tracks closed until next year or until Covid 19 is no more , this according to the tracks website
    Did however just made a test hit on a deserted stretch of road here in the Desert . Doing two test hits it blew the tires off once from the hit and other from a 20mph roll
    I guess I need to adjust / tune the suspension and new drag radials or slicks
    $ Mike 70 Z-28 likes this.
