what years did 350's have vortec heads
Discussion in 'Engine Topic' started by badazz70z28, Nov 9, 2012.
  1. badazz70z28
    badazz70z28 Veteran Member
    873
    Sep 12, 2004
    mechanicfalls maine usa
    I picked up an 87 iroc w a 350 tuneport motor. it goes ok but is high milage so i want to do a change this winter but i do not want to go carb, i want to keep the fuel system as it is.am i right in guessing that this has vortec heads on it? if so then any rebuilt motor with vortec heads will work correct ?
  2. Doug G
    Doug G Veteran Member
    354
    Nov 27, 1999
    Talking Rock, Ga.
    Vortec engines came out in 1995 for the 1996 model year. It was the first year V8 Vortec, but there were V6 and 4 cylinder engines that had similar combustion chambers starting in 1988. So, the tune port engines didn't come with Vortec heads, and they have a different intake manifold bolt pattern than the early heads. Check out the Vortec sticky for more info.
  3. badazz70z28
    873
    Sep 12, 2004
    thank you for the info
  4. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    Just put a bigblock in it:)
  5. Air_Adam
    Air_Adam Veteran Member
    2,927
    Feb 7, 2004
    Saskatoon, SK, Canada
    '96-99 for trucks, and '96-01 for vans I believe, for the "good" L31 vortec heads.
  6. badazz70z28
    873
    Sep 12, 2004
    thats a thought, i might have a good score on one, will find out soon
  7. F-Bodypilot
    F-Bodypilot Veteran Member
    342
    Jan 9, 2009
    Crescent Valley BC Canada
    If its the original 350 that was installed from the factory, then it's a L-98,.... good potential if you replace the factory tuned port intake with aftermarket FI or carb it. If you stick with the factory unit you will be limited to around 300 HP (installed).
  8. badazz70z28
    873
    Sep 12, 2004
    just ran the vin, def. coming out, it is the 305 tune port .ggrrrrr
  9. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    Did you sell you big block car?
  10. badazz70z28
    873
    Sep 12, 2004
    nope
