Wheel and Tire size help from the experts
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 74cam_mojo, May 8, 2008.
  1. 74cam_mojo
    74cam_mojo Member
    41
    Jun 13, 2004
    West of Chicago
    74 LT Proj
    soon I'm going to be at the point where the rubber is going meet the road. Existing wheels and tires are N/G. My sizing research is getting nowhere fast.
    This the undetailed effect I'm going for w/o compromising steering or rubbing.
    - rear=> Wheels 16's maybe 17's x ? to support med. profile FATTEST street tire that will fit. In other words more rubber than wheel.
    - front=> tryin for that raked look so I could drop down on the wheel dia. and a tire size that wont look odd compared to the rear w/o jagg'in w/ the handling.
    Also I'm buying new springs so should I get a drop size? if so how much!
    I know this is vague but any advise or pics would be appreciated. thanks
  2. blend120
    blend120 Veteran Member Lifetime Gold Member
    268
    Apr 11, 2006
    Goshen, NY
    Check the stickies at the top of the section.
  3. old zeder
    old zeder Veteran Member
    1,037
    Feb 21, 2007
    Guelph Ont. Canada
    Somthing along this line
  4. John Wright
    15,259
    419
    Aug 9, 2002
    Rustburg, Va
    Man, there are so many tire/rim choices...can you narrow your request down a bit more? Also, what looks like a tall sidewall to me may be totally different from what you had in mind.
