Wheel Stud Help
Discussion in 'Transmission & Driveline Topics' started by ratpatrol71z28, Jul 14, 2016.
  1. ratpatrol71z28
    ratpatrol71z28 Veteran Member
    1,577
    Mar 29, 2012
    Mantweeka, California
    Hey guys, I need longer wheel studs due to the disc brake conversion with the rotor taking up thread space.
    What is the factory 10 bolt stud length and what is a good length to go with for a street car?
    Shall I go with press in or screw in studs and is what is a good brand to go with?
    Thanks
  2. CorkyE
    11,259
    851
    Kieth at Custom Works sells an extended lug nut for C5 disk brake conversions, don't know if that will address your issue though. Scroll about half way down on this page.
    http://www.customworksperformance.net/brakes.html
    If you do replace wheel studs, ARP makes about the best, and press in should work fine on a street car.
  3. ratpatrol71z28
    1,577
    Mar 29, 2012
    Cool Thank you! I will take a look, I was leaning towards either ARP or Moser studs.
    Just checked out the longer studs Keith has and I am liking that idea alot! I didn't even think of that, thank you very much!
