Where are my Ford experts at?
Discussion in 'The BS Topic' started by AllensaurusRex, Aug 6, 2019.
Tags:
  1. AllensaurusRex
    AllensaurusRex Veteran Member
    544
    32
    May 22, 2013
    Murfreesboro TN
    Long story short, I have a 2003 Ford Ranger 3.0 2wd that has been in the family since new. Its been a great truck. Around 250k miles, I replaced the heads since these 3.0's have a common valve seat issue and it was burned out. I got another ~75k out of her, and she has been a joy to drive.
    About 2 months ago, I got a misfire CEL on cylinder 4. I did the below, in order, to no avail.
    1. I replaced plugs & wires (tried AC DELCO & Motorcraft)
    2. I replaced coil pack (Motorcraft)
    3. I replaced fuel injector (stock)
    4. Tested compression and was 'OK'. Hmmm...
      1. Around this time, I started getting a misfire on cyl 4 and 6 (WTH!?) :whine:
    5. I pulled the head entirely and took it to a machine shop. He said the valve seat was fine and it held great compression. He also refit the valve seals.
    6. On reassembly, I replaced the head gasket, valve cover gasket, intake gasket, and thermostat gasket. Torqued to spec. All done correctly.
    7. Now I have a misfire on cyl 4, 5, and 6 and a p0300 (or whichever one says misfire on multiple cylinders)
    8. I replaced the upstream o2 sensor
    The truck does run, but like an old 3 legged dog. Definitely running around 65-70% of full power. It's strange because the misfire is ONLY on the driver side bank.
    I took it to a local Ford stealership, and they said they would check timing next if they were me. I guess it is plausible that the timing chain jumped a tooth?...but I wanted to get y'alls thoughts on that before I tear it apart. It's never had the timing chain or waterpump done to date...but just seems a little strange to me that it would run THIS well, at all, with a timing issue.
  2. danbrennan
    danbrennan Veteran Member Lifetime Gold Member
    4,350
    1,238
    Mar 13, 1999
    Brighton, MI
    Could be the timing chain is just stretched, or the timing gear teeth worn, or both. I think the Ford 2003 3.0L is a dual overhead cam engine, with a timing chain. Those overhead cam engines have long timing chains, so they tend to stretch more than the shorter timing chain of a pushrod engine.
    Only other thing I can think of is an intermittent crankshaft sensor, but I would have thought that would set a crank or cam sensor fault. I thought that by 2003 all the OEMs were supposed to set a fault for the timing chain off by one tooth(or more), but I could be mistaken.
    Searching for the fault code associated with a stretched or jumped timing chain, I saw several articles that said one often hears a rattle coming from the front of the engine with a loose timing chain.
    Fuel pressure is okay? Only the misfire codes are set?
  3. gramps
    gramps Veteran Member
    1,866
    1,373
    Jul 5, 2009
    mankato, mn
    ^ the dohc 3.0 was only in the FWD based plateforms Taurus/escape the rangers had the venerable pushrod 3.0. Although The Taurus was available with both versions of the 3.0 which always makes looking up parts a little more interesting when people don’t know what 3.0 they have in their Taurus.
    If it was a timing chain issue, you’d have misfires on both banks.
    Being that you have checked compression and changed a bunch of parts, before you start throwing more parts in the cannon, have you looked at the data stream (more than a code reader) to see what it says?
    Have you looked at the cat converter on that bank? A plugged or partially plugged cat can cause misfires/driveability problems.
  4. frankz
    frankz Veteran Member
    2,125
    27
    Aug 24, 2009
    Illinois
    Sounds very similar to my first Ranger @ 185,000 miles . Turned out to be the computer. Ran like a champ after that.
  5. AllensaurusRex
    544
    32
    May 22, 2013
    Murfreesboro TN
    Yes, I will post those later today or tomorrow.
  6. AllensaurusRex
    544
    32
    May 22, 2013
    Murfreesboro TN
    Did you end up replacing the entire PCM?
  7. frankz
    2,125
    27
    Aug 24, 2009
    Illinois
    It was under $100 @ Napa when I did it.........
  8. zfool
    zfool Veteran Member
    657
    42
    May 19, 2014
    Rochester, MN
    Most of the Ford guys are waiting for a tow I suspect.
  9. jeff swisher
    jeff swisher Veteran Member
    1,889
    652
    Apr 26, 2018
    Yukon Oklahoma
    And this is why My Fords had carburetors.
    Hope you get it working.
    I had a few computerized swaps way back in the late 90's remove the FI and stick carbs on the engines.
    I have thought many times of doing it to some newer stuff.
  10. goofnrox
    goofnrox Veteran Member
    248
    29
    Nov 26, 2003
    Grand Rapids, MI , USA
    Yes because the 300K+ miles of reliable operation he got proves the FI to be a terrible Ford FI system. o_O
    Assuming the computer is reporting the misfires correctly, I think the mention about the clogged cat is probably on the right path.
