Where are you mounting your coil packs?
Discussion in 'High Tech Retrofits' started by SS Performance, Apr 16, 2020.
  1. djorgensen3
    djorgensen3 Veteran Member
    570
    80
    Oct 15, 2009
    Peoria, Az
    Cuz he has some sbc ones with custom company logos on them and he wants to use them....not because he is trying to make it look like a different engine.
    75Maro likes this.
  2. SS Performance
    SS Performance Veteran Member
    236
    36
    Nov 17, 2016
    Cape May Couny NJ
    Thank you
  3. Bill70
    Bill70 Veteran Member
    236
    19
    Jan 8, 2012
    Phoenix, AZ
    I have a 71 Camaro and a stock car with LSx engines. I moved the coils off the valve covers for convenience so I could check valve lash and springs more easily. The Camaro has the round truck coils behind the cylinder heads. It was tricky to do because they are bigger coils. For the stock car I used mounts and harness extensions from Michigan Motorsports using the flat LS3 coils. I mounted them to aluminum plates that attach to the motor mount bolts. The Camaro has the black valve covers, the stock car are red.
    John Wright likes this.
  4. SS Performance
    236
    36
    Nov 17, 2016
    Cape May Couny NJ
    Thanks Bill.
    I was worried that mounting using the motor mount bolts would get them too close to the headers. I was thinking about the back of the heads.
  5. John Wright
    14,881
    270
    Aug 9, 2002
    Rustburg, Va
    Nice setup Bill.
