Where do these clips go?
Discussion in 'Body Restoration' started by billkrz, Dec 24, 2020.
  1. billkrz
    billkrz Member
    91
    10
    Apr 25, 2015
    Waynesboro, Va
    Hi Folks and Merry Christmas to everyone. I have another question.
    I have several plastic clips and am unsure of where they go. I'm thinking the they go under the "Style Trim" chrome on the top of the doors. However, the chrome trim has already been installed.
    So, I am open to all suggestions and thank you in advance for your advice.
    Best Regards,
  2. Ihada70Z28B4
    Ihada70Z28B4 Veteran Member
    191
    26
    Oct 4, 2002
    Buffalo,NY,USA
    Yes, those look like "beltline molding" clips to me. Same part as "style trim" I assume.
  3. Twisted_Metal
    29,670
    2,517
    Yes.
    Those are the clips which hold the trim at the top edge of the doors.
    (Z21 trim option)
    They slide over the studs welded to the door skins and the trim snaps over them.
  4. billkrz
    billkrz Member
    91
    10
    Apr 25, 2015
    Waynesboro, Va
    Thank you!
    Hmm..I wonder how the shop mounted the new upper "style trim" without these? I wonder if the new "style trim" pieces came with clips? Anyone know?
  5. billkrz
    billkrz Member
    91
    10
    Apr 25, 2015
    Waynesboro, Va
    Also, the clips seem to have different heights. Do they have specific locations?
  6. ChevyReb
    4,331
    213
    Feb 4, 2003
    SC
    The repop ones are too big and have to be measured and sanded down 10 or so thousands in order for the trim to fit over them. (Shoutout to NZ28 member bordog for educating me on that tidbit) And even then they are a somb!tch to put on without scraping the new paint off. It i ever paint my car again I will be deleting that z21 option and cutting off the studs they lock onto.
  7. sprink
    sprink Veteran Member
    577
    185
    Apr 27, 2008
    ffx, va
    Maybe your hood had belt molding?
  8. ChevyReb
    4,331
    213
    Feb 4, 2003
    SC
    I have a cowl hood so factory trim won't fit that. Its the clips on the top of doors and door molding that is the issue. The hood and fender tips don't use those clips.
  9. bodymanbill
    bodymanbill Veteran Member
    1,706
    1,373
    Feb 1, 2007
    South Park Pa
    DA77A3A5-0314-44A5-8A55-BE05912F5EFA.png Here’s the upper stainless trim clip installed, looks like the two different one in the pic are for the lower Type LT trim that goes on the doors, 1/4s and fenders.
  10. xten
    xten Veteran Member
    4,184
    3,192
    Sep 24, 2014
    Pittsburgh, Pa.
    Some of them look like they could be from a vinyl roof molding.
