Where to find 8 ohm speaker
Discussion in 'Car Audio, Electronics & Security' started by FredG70SS, Aug 20, 2007.
  1. FredG70SS
    FredG70SS Veteran Member
    159
    Dec 3, 2005
    Burlington, Ontario
    I need ot replace the front speaker in my 70 Camaro. Does anyone know where to buy a replacement for ther original?
    Thanks
  2. 68400BIRD
    68400BIRD Veteran Member
    2,955
    12
    Feb 7, 2006
    GO PACK GO
    Are you looking for an original size speaker to mount in the stock location? You can also mount two smaller speakers in the stock location using the old speaker housing. It sounds much better that the stock 1 way speaker. You can do a search on front speaker and see how it was done.
  3. FredG70SS
    159
    Dec 3, 2005
    Burlington, Ontario
    Yes I am looking for a stock speaker. I'm putting in a correct Am radio and taking out the AMFM CD that was in it. There are two small speakers in in now, they are marked 4 ohms each. If I put both of those wires together does that make 8 ohms?
  4. sikzdrivr
    sikzdrivr Veteran Member
    699
    Jul 17, 2003
    canada
    No that will make a 2 ohm load and you will fry your power supply.
  5. FredG70SS
    159
    Dec 3, 2005
    Burlington, Ontario
    I can use the two 4 ohm speakers in series. The two speakers will work like a single 8 ohm mono unit. I found that by a google search of speaker wiring.
    Case closed - thanks for the help.
  6. iregret
    iregret Veteran Member Lifetime Gold Member
    1,094
    Apr 21, 2003
    Land of enlightenment.
    Glad you figured it out! Think flashlight batteries.
  7. Little Naples
    Little Naples Veteran Member
    1,287
    Oct 10, 2004
    Marin County, California
    I replaced my original speaker with one from a local store called Electronics Plus (it's like Radio Shack)....it was the exact same size and has a little tweeter built in (co-axial) so it has better tone than the original....works great with the original AM radio.
    http://www.electronicplus.com/
  8. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    in SERIES it makes 8 ohms
    pos from radio to pos at spk 1
    neg of spk 1 to pos of spk 2
    neg of spk 2 to neg of radio.
    in parallel its 2 ohms
    pos radio to pos of spk 1 and spk 2
    neg of radio to neg of spk1 and spk 2
  9. rhead007
    rhead007 Veteran Member
    2,456
    Oct 25, 2000
    BOLINGBROOK ILL USA
    why not just use a resistor in line to get the proper ohmage
  10. Eric
    Eric Veteran Member Lifetime Gold Member
    11,275
    Jun 4, 1999
    Somewhere, Out Here, In the World
    Was a 1970 factory system designed to use 8-ohm speakers? The audio world is mainly 2 and 4-ohm these days.
