Where to ground?
Discussion in 'Car Audio, Electronics & Security' started by Shields, Apr 1, 2015.
  1. Shields
    Shields Veteran Member
    117
    Nov 19, 2013
    kelowna, british columbia
    I just got some 1 gauge wire and am looking for a decent spot to ground my amps to, my mdf board bolts up to the trunk divider, an theres just enough from for wiring to sneak between the divider and the MDF board, where can I ground my amps? I want to keep the wire hidden. I could easily just ground it off the actual divider but I would like some opinions
  2. grzewnicki
    3,467
    188
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Grind the paint or primer back off the divider sheet metal, drill a hole and bolt the terminal down, you'll be good to go.
  3. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    I have yet to put anything into cars like ours, but from what I understand you should attach a ground wire from the battery negative post to the rear frame rails. Our cars are similar to a unibody, but instead of the entire car being tied into one frame, there is a subframe the front clip attaches to, then it's bolted to the rear half of the car underneath the floorboards.
    http://en.wikipedia.org/wiki/Subframe
    The jest of it is, there are no real solid sections of the car that are connected well enough to be capable of handling the type of load an amplifier is going to put on the electrical system. Additional connections are recommended.
  4. Fbird
    4,624
    926
    Feb 12, 2011
    atlanta, ga
    as AJ stated...
    Basically you need to daisy chain ground everything
    Battery negative --> frame rail
    frame --> motor
    frame to body shell
    to ensure things work well. ;)
