Where's The Best Place To Mount Electric Fuel Pump?
Discussion in 'Engine Topic' started by 1BAD78, Apr 14, 2010.
  1. 1BAD78
    1BAD78 Veteran Member Gold Member
    814
    Apr 12, 2007
    Broken Arrow Ok
    I Have A 78 Z28 This Is My First Electric Fuel Pump And I Was Wondering Where Would Be The Best Place To Mount It.
  2. theflash
    11,044
    36
    Feb 27, 2004
    Podunk, CT
    Do you have a cross flow muffler?
  3. 1BAD78
    814
    Apr 12, 2007
    Broken Arrow Ok
    NO IM RUNNIN DUAL FLOWMASTERS WITH TURN DOWNS BEFORE THE AXLE.
  4. muscl car
    23,099
    1,592
    Jul 8, 2001
    SoCal High Desert
    mount the pump with a bracket up against the back wall of the trunk floor
  5. mrdragster1970
    7,821
    507
    Apr 12, 2007
    In the trunk!!
  6. DoTheDew
    DoTheDew Veteran Member
    899
    Mar 2, 2010
    Leduc, Alberta
    DO NOT PUT IT IN THE TRUNK. They do get hot, and could overheat. Should be exposed, and you don't want fuel coming inside the cabin anywheres. Make a bracket and attach to the side of one of the rear frame rails
  7. mrdragster1970
    7,821
    507
    Apr 12, 2007
    WOW, I guess I've been doing wrong for 20 years, and about 50 guys I know also.
  8. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    In the tank.
    Where they are at on every newer vehicle made today.
  9. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    Ding, in the tank is the best spot. Pumps don't like to suck fuel. They want to push it. Second best is anywhere as close to the tamk as possible and even or below the bottom.
  10. 1BAD78
    814
    Apr 12, 2007
    Broken Arrow Ok
    its an external pump.its the holley blue logo.
