Which bilstein shocks ..
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 71Z28RS, May 23, 2020 at 10:36 AM.
  1. 71Z28RS
    71Z28RS Veteran Member Lifetime Gold Member
    304
    16
    Jul 19, 2014
    Toronto
    I will be replacing the front and rear shocks on my 71 soon 66E7CD9C-24FC-4698-A638-F083464456F3.jpeg and I’ve been reading good things about Bilstein shocks on this forum and was hoping to get a recommendation on what part number I should use
    Running 215/65/15 in the fronts and 255/65/15 in the rear.
    New front springs were replaced about 6 years ago with oem rating
    I know I need to replace both body mounts And F/R shocks
    I am trying to eliminate as much body noise as I can
    TIA
  2. Lowend
    15,284
    612
    Mar 25, 1999
    San Jose, CA, USA
    I believe that Bilstien has collapsed all of their 2nd gen street shocks down to the “B6” line.
    Unless you go with a custom valving, which you don’t need, there’s only one part # per axel
    71Z28RS likes this.
  3. 75Motion
    75Motion Veteran Member
    358
    8
    Jan 26, 2008
    Ohio
    They have their B6 shocks and drag shocks. For the street you would get the B6 shocks.
    Part #24-029728 up front and Part #24-001564 in the rear.
    71Z28RS likes this.
  4. 71Z28RS
    304
    16
    Jul 19, 2014
    Toronto
    Thanks guys , much obliged
  5. camaro71/holland
    1,295
    104
    Aug 27, 2003
    The Netherlands
    71Z28RS likes this.
  6. 71Z28RS
    304
    16
    Jul 19, 2014
    Toronto
    Thank you , , thank you very much ;)
  7. Bandit723
    Bandit723 Veteran Member
    3,194
    474
    Oct 1, 2016
    Waupaca WI
    What is the shock length for the rears.
