Which pistons to use?
Discussion in 'Engine Topic' started by maguyvr, Nov 19, 2015.
  1. 450bench
    450bench Veteran Member
    3,413
    154
    Feb 25, 2002
    memphis, tn-shelby
    TRW part number L2304 .040
    They are the factory replacements
  2. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    That's the one!
  3. Rich Schmidt
    Rich Schmidt Veteran Member
    4,285
    40
    Mar 27, 2010
    Denville NJ
    Yup,those are the ones. Kinda heavy,but plenty strong. I ran them in a whole bunch of 600+ HP nitrous engines over the years. The last set I had,I had fly cut about .070 in the valve notches,and routinely shot a 300 HP plate thru it in an 8000 rpm engine. I would melt spark plugs,and push the best head gaskets out,multiple times,and the pistons held up fine.
  4. maguyvr
    maguyvr Member
    53
    Feb 25, 2015
    Woodland,ca
    Perfect. Thanks!
  5. Lowend
    16,334
    1,189
    Mar 25, 1999
    San Jose, CA, USA
  6. maguyvr
    maguyvr Member
    53
    Feb 25, 2015
    Woodland,ca
    Thanks for the tip. I will consider it.
  7. mrdragster1970
    7,821
    507
    Apr 12, 2007
    You can also soften the piston if you think you might risk detonation.
    I have no clue if it helps on a street engine, but it definitely helps us.
  8. Rich Schmidt
    4,285
    40
    Mar 27, 2010
    Denville NJ
    How the heck do you do that?
  9. mark wagner
    mark wagner Veteran Member
    2,131
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    probably means to smooth the sharp edges on the dome
  10. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Can't see the ??, that poster is on the block moron list, but yes, we soften all the possible hot spots on the piston and head.
