Which plugs? 781 big block....
Discussion in 'Troubleshooting & Diagnosis' started by Soundwave, Jul 31, 2017.
  1. Soundwave
    Soundwave New Member
    19
    Apr 26, 2017
    So, ive been all
    Over this car chasing performance issues, car wont move under full throttle.... super flat acceration..... list if parts:
    781 heads, mild cam and flat top pistons, so low comp.... but....
    Replaced fuel pump and filters
    Hei dist, then added msd 6a
    3k stall with 373s
    Plug wires....
    But, getting mixed plug recommendations... the ones i have now come back for a lawnmower.. i had the r44ts, short reach, but idle was rough, put the mower ones back in, long reach 13/16 hotter plug..... just ordered champions
  2. Soundwave
    19
    Apr 26, 2017
    CHampions 57yc? 5/8 long reach....
    Timing is at 10, any higher and i get timing ping.. at light throttle at 2500 rpms... with 93 fuel.... plus rougher idle.... im beyond stumped with this
    Motor... almost feels like its not gettinf fuel, but has a new holley 850 (way too much carb, but all i had)
  3. 77Z28454
    77Z28454 Veteran Member Lifetime Gold Member
    105
    13
    Aug 24, 2007
    Ontario
    I've had good luck with Autolite 24's I'm no engine expert but 10 degrees of timing and having pinging seems low.
  4. Soundwave
    19
    Apr 26, 2017
    Was pinging when i had initial around 12-14..... car not happy!
    Which heads are you running?
  5. 496z28
    496z28 Veteran Member Lifetime Gold Member
    967
    8
    Sep 23, 2007
    Oklahoma City
    I had the same problem with my dually. Never got it figured out. I was running NGK UR5 plugs.
  6. Soundwave
    19
    Apr 26, 2017
    Pretty sure this isnt my problem, but worth a shot! What was yours doing?
