Which stance does your car have?
Discussion in 'The BS Topic' started by 1971CamaroGuy, Jan 23, 2018.
  1. connorbe
    connorbe Member
    43
    Jul 5, 2017
    South Dakota
    If you don't mind me asking, what mods did you do to your front suspension to achieve your ride height? I have a very similar wheel/tire setup and I like your stance a lot.
  2. APEowner
    APEowner Veteran Member
    646
    12
    Dec 9, 2013
    Albuquerque, NM
    I don't mind at all. I've got QA1 double adjustable coil overs on the front so I can set the ride height where ever I want. To get the suspension geometry where it needs to be I'm running tall upper and lower ball joints. I had to shorten the bump stops to get some suspension travel but it's still not really enough because it hits the bump stops on corners where I turn in aggressively under breaking or when the suspension is heavily loaded from an elevation change. I'm working on building new lower control arms to address that problem.
    The rear suspension is custom springs with spherical bushings in the front eyes and spring sliders in the rear. I did the Herb Adams mod to get the roll center where I want it. I'm running AFCO double adjustable shocks on the rear
    Both ends of the car have PTFB adjustable bars.
  3. Zspoiler
    Zspoiler Veteran Member
    3,533
    299
    May 6, 2012
    Federal Way, Washington
    I have Vette Brakes C-4 Corvette adjustable mono-leaf adjustble front suspension .The rear are 1979 Z-28/WS-6 rear leaf springs. 130044932860518017_26257430996_o (1).jpg
  4. ronzz572
    2,188
    116
    Feb 8, 2007
    imperial pa
    My 70 firebird has a hotchkis tvs kit with 2 inch drop 18 inch wheels. 20180117_201704.jpg 20180117_201704.jpg 20180117_201718.jpg
    dave@ztech likes this.
  5. CamaroII
    CamaroII Member
    53
    Feb 22, 2018
  6. CamaroII
    CamaroII Member
    53
    Feb 22, 2018
    John Wright likes this.
  7. CamaroII
    CamaroII Member
    53
    Feb 22, 2018
    love the look, would like to know what wheel size and width you are running and if there was any back spacing and tire size. thanks
  8. chevyJeff1
    chevyJeff1 Veteran Member
    750
    45
    Nov 2, 2002
    Shenandoah VA. Listening to the blues
    Good stuff!
    Wide track is one that can't go wrong with second gen Camaro's.
  9. SRGN
    SRGN Veteran Member
    681
    239
    Feb 20, 2009
    Central NJ
    Is nose up without a drivetrain considered a "stance"? Lol
  10. John Wright
    14,881
    270
    Aug 9, 2002
    Rustburg, Va
    17x8 255/40 at the front, 17x9 275/40 at the rear....off the shelf back spaces for yhe Cragar Soft 8 wheels
