Curious who here is using a VPN, which one and why.
I'm using PIA also. I had it connected to my PFSENSE router as you do, but was constantly playing a cat and mouse with Netflix etc. My next step was to create a VLAN and put all the Roku's etc on that net to bypass the VPN. Is that what you did?I use Private internet access due to it's price (I have a discount for being on it for almost 4 years, I think prices increased)
it's privacy policy as it doesn't keep logs
and the amount of servers to choose from in the event a website blocks which one you're connected to (which sadly is unavoidable)
I haven't experienced a lot of downtime, and if I do, just switch what server I'm connected to. It also doesn't impact my speeds too much. (if you put on stronger encryption it will obviously go down, but all depends on what you're looking for)
I personally never turn it off and have it configured through my router so all devices are always on a VPN no matter what. I also have something called a pi-hole that gets rid of all ads in my house, including the TV.
Yup, I just set up lan rules and change what that devices default gateway if I run into issuesI'm using PIA also. I had it connected to my PFSENSE router as you do, but was constantly playing a cat and mouse with Netflix etc. My next step was to create a VLAN and put all the Roku's etc on that net to bypass the VPN. Is that what you did?
Interested in the Pi-hole. Can you point to how you set yours up?
