whining noise need advice
Discussion in 'Transmission & Driveline Topics' started by HULKZ28, Jun 19, 2014.
  1. HULKZ28
    HULKZ28 Veteran Member
    1,572
    Oct 15, 2005
    Jeffersonville NY USA
    when I let off the throttle it wines pretty bad, all gears.coasting.if I give any throttle, or push in clutch, the noise goes away..trans is a rich t10 with under 2000 miles....was fine when I parked it last week.. dumped the trans gear oil and rear and don't see any metal flake..help!!
  2. big gear head
    big gear head Veteran Member
    6,398
    172
    Jul 30, 2001
    Central City, Ky.
    Check the pinion nut. It's probably loose. Torque it to 125 foot pounds and see if the noise goes away.
  3. HULKZ28
    1,572
    Oct 15, 2005
    thanks BGH, exactly what it was..what makes that loosen up.??I put red Loctite on it and torqued it..all better..
  4. big gear head
    6,398
    172
    Jul 30, 2001
    Central City, Ky.
    Just the twist of the driveline. Somehow they get loose sometimes.
  5. HULKZ28
    1,572
    Oct 15, 2005
    beatin on it probably dosnt help..thx again..
  6. big gear head
    6,398
    172
    Jul 30, 2001
    Central City, Ky.
    I'm glad it was something simple.
