who 's 74 has drip rail ?
Discussion in '1974 Specific' started by m00n1957, Nov 19, 2020.
  1. m00n1957
    m00n1957 Veteran Member
    654
    Jun 20, 2003
    blue mountain,ms USA
    i've noticed several with a drip rail, my 74 z/28 doesn't have it. i also notice the chrome trim on the window seal stops at the drip rail on cars that have it instead of it continuing around hood on cars without it.
  2. Z28PILOT
    Z28PILOT Veteran Member Lifetime Gold Member
    2,096
    59
    Oct 8, 2009
    Emerald Isle , NC
    My car has the chrome plastic rails above the windows , bright molding across the back of the hood , the small matching pieces of brite molding at top corner of each fender and at bottom of door window edge. And the thin bright little strips verticle on the door edge guards . My car is pretty basic , but oddly enough was equipped the extra cost upper trim package "Z21 " on my sport coupe model and hide a way wipper system. This trim pkg included door handles that have the body color painted inserts . Other than D88 decals and std. lower rocker moldings my car is devoid of bling .
  3. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,420
    101
    Jan 1, 2005
    Schererville,In.46375
    My car has the plastic gutters.....Iā€™m surprised my car did not come with the Z21 package since it has everything else....AC,Tilt,AM/FM Stereo,PW,SpaceSaver, and Auxiliary Lighting.
  4. mallard
    mallard Veteran Member
    930
    246
    Oct 3, 2013
    SK, Canada
    My '74 has the drip moldings but not the bright work at the back of the hood around the windshield area, the door edge guards nor the body side moldings.
  5. Jonesy
    Jonesy Veteran Member
    505
    38
    Jun 7, 2008
    Minnesota
    Same with mine. Only the plastic drip rail moldings
  6. mallard
    930
    246
    Oct 3, 2013
    SK, Canada
    Sharp non stripe car! Still have the rear panel mouldings unique to ā€˜74 & ā€˜75?
  7. Jonesy
    505
    38
    Jun 7, 2008
    Minnesota
    Yes, this car still has 80% of its original paint. Moldings have never been off the car
    Kricka and 74Z28GC3 like this.
  8. mallard
    930
    246
    Oct 3, 2013
    SK, Canada
    Lucky you. When I bought my '74 in '84 (46000 miles) those rear mouldings had already fallen off and you could see the non-faded impression areas in the paint. Most of those models had those mouldings fall off so you're most fortunate to have yours in place.
  9. Jonesy
    505
    38
    Jun 7, 2008
    Minnesota
    Yes, I know. I dont think my car was ever left out in the weather. It was not driven since 1985 and sat in a garage.
    The original owner had it until it had 17,000 miles on it and the 2nd owner (his friend) bought it and drove it until 32,000.
    Then it needed a tune up. He couldnt get it running after the tune-up so it sat. I bought it in 2009. The original wheels/tires were taken off when new.
    He ran cragars on it. Then took them off to sell it and put the originals back on. They were like brand new.
    Anyways I drained the tank and lines, rebuilt the carb and I couldnt get it to fire.
    Ended up the guy put points in it and one of the wires to the points was touching the base of the distributor and grounding out.
    I moved it up and it fired right up. Car drives real nice as its never been taken apart.
