Who sells the best fitting carpet ?
Discussion in 'Interior Restoration' started by Orange_Z, Oct 8, 2021.
  1. Orange_Z
    Orange_Z New Member
    Oct 6, 2021
    Looking for a good fitting replacement carpet for my 80 Z28. Earlier this year I replaced the carpet in my 96 Impala with ACC carpet and was not impressed with the quality or fitment. Don't mind dropping more money for better quality.
  2. DougD
    DougD Veteran Member
    410
    142
    Dec 2, 2014
    Bradenton, FL
    IMO nobody makes good replacement carpet these days
  3. Allison Winn
    Allison Winn Veteran Member
    295
    50
    Jan 10, 2021
    Agreed
    Best I have seen is a decent fit with contours that aren't as tight fitting as you'd like. For me a simple fix - a heat gun. Hair dryers and steam wands won't get you there. I used a Leister Roofing heat welder. Get some HEAT up under the back side and it will form fit however you like.
  4. l16pilot
    2,122
    277
    Dec 13, 2004
    Hurlock, MD, USA
    I've used ACC's carpet in two 1970 Z28s...the standard loop carpet, (per factory original), does not fit well. For the 70Z I just finished, I tried their standard loop carpet with mass backing. World of difference and fits very nice. Also, as Allison mentioned, a heat gun helps a lot from the back side because you can melt the rayon carpet fibers if heat is applied to the carpet side.
  5. Allison Winn
    295
    50
    Jan 10, 2021
    YES - forgot to stress the high heat goes on the back side only.
    My last ACC kit the jute backing was glued about 6" out of place so I had to peel it off, scrape it down, and re glue :(
  6. DougD
    410
    142
    Dec 2, 2014
    Bradenton, FL
    Somewhere I remember a detailed thread of how ACC was a disaster on fitment.
  7. BillyDean7173
    BillyDean7173 Psychopathy Red
    3,179
    1,197
    May 21, 2014
    Hutto, TX
    Same here. Got mine about four years ago. Very happy with it.
  8. rocket dawg
    rocket dawg Veteran Member
    520
    71
    May 5, 2015
    Grand Rapids Mi
    I did ACC about 2 years ago and it fit very nice. It was probably the standard loop with mass backing, I cant remember exactly.
  9. 70lt1z28
    4,570
    1,142
    Oct 3, 1999
    Beavercreek, Ohio, USA
    On the ACC site...maybe a dumb question..what is a "Tail Loop"
  10. Ratty_81
    Ratty_81 Veteran Member
    274
    147
    Nov 13, 2020
    I’m in the process of putting the acc standard cut loop in my 81. Cut out for the console not even close and seems to be way too loose at the front of the trans tunnel. Rest seems to fit pretty well and follows the humps and dips in the floors good. My rear foot wells are tough to judge because I have subframe connectors running through them. I put foam on either side of the tubing to try to make the area somewhat flat.
