WiFi users
CorkyE
12,121
So that's why Netgear came out with a security firmware update to my router? This is an older (5yr) router that's been discontinued with no updates available.
Gary S
24,984
As I understand the article, not only the router needs to be updated, but every device that connects to it will need a security patch. To get into your home WiFi, they need to be in range of it so you aren't likely the #1 target as this spreads around. However, any public WiFi will be more likely to get hit, and anybody that connects to a public WiFi with any portable device would then be open to the attack.
Camaro75LT
Masshole
6,651
Boston-ish
The older routers have been subject to the man in that middle attack for a long time. Security has always been a cat and mouse game. Thanks for the link.
Knuckle Dragger
Mayor of Simpleton
17,275
Waddell AZ
I have a little newer router but I was surprised when I got a pop up warning to upgrade the firmware. I assume now it was over this.
CorkyE
12,121
Mine is an older WNDR4500 and I got a notification from Netgear on Oct 5th about this. I did not download the update, I let the router connect and update. I can forward the email if you want.
Gary S
24,984
Here is more information about the problem. It appears that if your computer is up to date, it could already be patched and safe. Routers, phones, and other internet devices probably don't have updated patches yet, but the routers can't be hurt. They just allow a path for the hackers to get into your system. If your end equipment is patched, you are still likely OK.
http://www.zdnet.com/article/here-is-every-patch-for-krack-wi-fi-attack-available-right-now/
