Will a 6.0 LQ4 engine connect to a 700r-4?
Discussion in 'High Tech Retrofits' started by ProjectCam76, Sep 2, 2015.
  1. ProjectCam76
    ProjectCam76 Veteran Member Lifetime Gold Member
    275
    Aug 10, 2015
    Birmingham, Alabama
    So I found out from my local junk yard that I could get a 2007 or newer 6.0 LQ4 truck engine for around $3k but he said that's without wiring harness and just the engine alone. He said wiring harness with brain will cost even more. I plan on running a 700r-4 and need clarification that it will connect to the LQ4 or do I need an adapter plate? Also, would it be better to just buy an aftermarket wiring harness & brain. Rather than buy the wiring harness that would've been attached to the LQ4 engine. If I do this then I plan on sticking a LT4 hot cam in it.
  2. ProjectCam76
    275
    Aug 10, 2015
    Birmingham, Alabama
    I read somewhere it would probably a lot less headache to use a 4L60E rather than a 700r-4 though.
  3. 2nd gen Guy
    2nd gen Guy Veteran Member
    612
    Jul 29, 2012
    Coon Rapids, Mn
    For a few more $$ you can get a crate engine if your gonna spend that kind of dough. Might b worth it for what you get, IMO.
    Oh, and I have no idea about the trans fitment
  4. ProjectCam76
    275
    Aug 10, 2015
    Birmingham, Alabama
    True, and I've been considering that too.
  5. griffsbombelco
    griffsbombelco Veteran Member
    220
    Aug 17, 2009
    socal
    Too much $$ for that engine they can be had for at least a grand less complete
  6. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    X2. Way too much dough....
  7. badazz81z28
    18,068
    796
    Alabama
    Maybe if it was an LQ9 that value I see is $2500. For $3k, I would be looking for low miles and complete. The LQ4 engine are dirt cheap. The LQ4 depending on year cast or aluminum cathedral port heads?
  8. nobreaks254
    nobreaks254 Veteran Member
    501
    9
    Jul 14, 2007
    aberdeen, SD
    lq4 and lq9 are cathedral port motors. L92 would have rectangular heads
  9. Camaro_73
    Camaro_73 Veteran Member
    445
    20
    Mar 10, 2014
    Belton,TX
    Even if it is an lq9 NEVER PAY 3000$ FOR ONE. 6.2s can be had for 3500$ also COMPLETE .
    Although 07 and newer have the better flowing heads. You should never pay that much for an iron block truck motor. Especially with no harness or computer.Get you a COMPLETE lq4 for 1200$ and spend the rest of that 3k on cam, heads, and springs and a 4l80e.
    You can run a 700r4 and you don't need a flexplate KIT if you get the 4l80e flexplate with the motor. But you will need the spacer. If you don't get the 4l80e flexplate then you will need the whole kit.
    As far as running a 700r4 you will need to buy a kickdown cable conversion since the fuel injection motor doesn't have anything to hook the kickdown to.
    If I were you I'd stick a 4l80e behind it or at least a 4l60e.
    As far as the harness you can get a stock one a re work it yourself, send it out to get re worked or buy one for around 500$ shipped to your door.
    Junkyards have caught on to people using the LS motors in swaps so the price of them is much higher than it used to be. And they know people with little to no knowledge of the motors will pay that much. I learned the hard way when I first started out and spent way to much money because of my lack of knowledge. Definitely look around a lot more. Join the fb groups "lsx parts for sale, lsx swaps, lsx parts for sell or trade". I'm sure somebody on those pages lives close to you and either has a motor or knows where to get one much cheaper.
    Hope i helped.
  10. Kamaro
    Kamaro Veteran Member
    277
    Oct 31, 2010
    Doha
    $3000 is too much even for a fully dressed LQ4, a few years ago I picked up a complete low mileage LS2 and T56 with everything (harness, ecu, pedals, .. etc) for about $5000.
