Will Edelbrock Performer Rpm fuel pump fit 81 Camaro
Discussion in 'Engine Topic' started by AJ81Z28, Nov 25, 2020.
  1. AJ81Z28
    AJ81Z28 Member
    49
    Mar 21, 2017
    Has anyone tried an Edelbrock Performer RPM fuel pump on an 81 Camaro? The stock ones I get from Autozone, which are Delphi brand keep breaking. The lever pin will break loose from the housing. I wanted a fuel pump with the lever pin mounted from the outside so it won't pop out anymore.
    It's a 327 small block with the stock clamshell motor mounts
    So anyways I was just looking at the fuel pump area and not sure if there is enough clearance from the motor mounts. I appreciate any help. Thanks
    https://www.edelbrock.com/performer...ump-for-big-block-chevrolet-110-gph-1721.html
  2. GoldenOne7710
    5,467
    785
    Jun 23, 2004
    Athens, GA
    Those have a adjustable bottom so you can "clock" where you want the inlets and outlets. Should fit fine.
  3. Lowend
    16,207
    1,144
    Mar 25, 1999
    San Jose, CA, USA
    There's a conversion plate that fits on the bottom.
    But honestly, Don't use that pump. Even my old Edelbrock rep told me those were pieces of crap.
  4. biker
    biker Veteran Member
    3,157
    1,367
    Dec 7, 2014
    Same. No luck with edelbrock pumps and even clocked, clearance is iffy.
    Try a Carter muscle car pump. Not expensive and reliable.
  5. BonzoHansen
    20,673
    1,761
    Jun 1, 2005
    Scott from Hamilton, NJ
    Buy a stock replacement carter.
  6. AJ81Z28
    AJ81Z28 Member
    49
    Mar 21, 2017
    Ok thanks. So is there a particular Carter you guys are talking about?
  7. BonzoHansen
    20,673
    1,761
    Jun 1, 2005
    With or without return line?
  8. AJ81Z28
    AJ81Z28 Member
    49
    Mar 21, 2017
    It has the return line but I can just block that off. I liked the lever pin design of the Edelbrock. It comes from the outside and the pin is totally encased on the inside as opposed to the OEM ones from autozone. Is there a good one similar to the Edelbrock? I looked up Carter and they have one that looks just like the Edelbrock but not shiny
  9. BonzoHansen
    20,673
    1,761
    Jun 1, 2005
    No, keep it. it helps with vapor lock.
    Carter shows these 2 for an 81. I'm surprised the 3 line is a large body. Is yours like that?
  10. BonzoHansen
    20,673
    1,761
    Jun 1, 2005
    I've been thinking about this. how many have you broke?
