Will Spiral shocks # 3197691 for a Vega work on a '71 Z28
Eric winkel
65
I'm hoping these date coded Vega shocks will bolt right to my Z, any thoughts?
22,719
Z28 shocks were a special item for the Performance Suspension. Why would you put Vega shocks on a Z28? It would be the same a installing 6 cyl Camaro springs in a Z28. You just wouldn’t do it.
Eric winkel
65
I figured they would be better than repo being date coded and didn't want to spend the $$ Not even sure if I would able to find the correct 3192282 shocks.
They should bolt up, correct?
Thanks
22,719
I knew it was about the $.
I have no idea. Put the shocks side by side and match up the 3 mounting areas, 2 on top and 1 on the bottom.
