Wilwood disk clearence
cisco 1
48
quebec,canada
Any idea ?
90 degree will not help
Driver side only
cisco 1
48
quebec,canada
those hare edelbrock shock that i painted grey .
i have 6 inch from robber bumper to diff but have lest from fitting to shock body
1973 z-28
G72Zed
4,411
I had the same issue as well, but shock body the other way, so eliminates that variable.
Used extension and moved the mount a little less than .250 and used a 90* fitting. No issues or rubbing.
CorkyE
11,931
I'm not familiar with Wilwood, I used a different brand. However the supplier was very specific about the setup being for staggered or non staggered shocks. Does this play any role in your issue?
73 Z
1,284
Los Angeles, Ca
I mounted the calipers 180 or opposite side of lower shock mount. you by chance have 2 rights, bleed valve is always at top
cisco 1
48
quebec,canada
I am not woried about the shock chrome shaft , i am more woried about the shock body ( were the seal is ) wen the back suspencion is going to skuish that it going to hit fitting
Maybe i do not understand someting
73 Z
1,284
Los Angeles, Ca
If this retrofit is based off a bolt on kit using original style suspension set up, the calipers are mounted the opposite side of shock with the brake bleeder at the top.
Sean77LT
11
Any idea ?
Driver side only
Hey bud. I know this is gonna be a bummer, but I did it too. Call Wilwood and explain it, they will send you the correct caliper bracket that puts its in front of the axle, so opposite of the shock. Same way the passenger side is set up. The bracket is like $43, and, they might "help you out" on the price a bit if you explain it humbly enough. Lol. It was this thread that prompted my call to them. I just got mine together, had the same issue, searched it, saw this thread, and called them today. Damn interwebs is really something, huh? Good luck.
Sean
