Wilwood front disc kit help
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Bi11, Dec 7, 2020.
  1. Bi11
    Bi11 New Member
    13
    Dec 6, 2016
    NOVA
    Gents, I upgraded to this kit from Summit https://www.summitracing.com/parts/rsd-rcp79s along with a new, stock replacement MC (1.2 inch bore) with vacuum booster. Bled the lines thoroughly and the pedal is very firm, but I have pretty weak stopping power. The calipers are functioning as they should and I bench bled the MC before installing it. What gives? Do I need a smaller bore MC? Is it because I haven't broken in the new rotors and pads? At this point I don't feel safe driving it on the road to break them in. Thanks for the help. IMG_0973.jpg IMG_0922.jpg
  2. dcozzi
    dcozzi Veteran Member
    4,239
    1,207
    May 1, 2002
    Phoenix, AZ
    Is the vacuum booster working?
  3. Bi11
    Bi11 New Member
    13
    Dec 6, 2016
    NOVA
    Going to test on it today and find out. I assume I can try it with and without the vacuum line hooked up to confirm. Does that sound right?
  4. CorkyE
    11,393
    915
    Don't see why not. Plug the vacuum line at the carburetor/intake, you may have a different idle speed. Also do this at a very low speed, like while still in your driveway.
  5. flybye70ss
    flybye70ss Veteran Member
    924
    57
    Dec 6, 2002
    Allen, TX
    My Wilwoods needed to be bedded before they stopped well at all.
  6. badazz81z28
    21,031
    1,484
    Alabama
    For maximum performance I agree, but should work right out of the box. Questioning their function and your means to stop is a matter of an issue, not pads being embedded.
  7. Bi11
    Bi11 New Member
    13
    Dec 6, 2016
    NOVA
    I'll test on her this weekend and report back. The weak link in all this is the vacuum booster, it is the only thing that I have not replaced. Getting the windshield installed today, so I can actually drive it without getting frost bite. LOL
