window crank stud
Discussion in 'Interior Restoration' started by greencamaro1981, Jun 7, 2014.
  1. greencamaro1981
    greencamaro1981 Veteran Member
    604
    Jun 2, 2010
    Montana
    the window crank stud is ground off so the crank will not engage any easy fixes or is it a full replacement
  2. azkeebler
    azkeebler Veteran Member
    584
    Dec 14, 2011
    Manteca, ca.
    You can drill out the three rivets in the housing for the stud and swap the stud out, if you have another. Otherwise , replacing is your best option.
  3. Trashman
    Trashman New Member
    16
    Jan 22, 2012
    Indianapolis, IN
    I welded on tabs 180 degrees across from each other and ground the welds to match the crank handle. Its tight and work fine.
