Window seal leaks
Discussion in 'Interior Restoration' started by Steve Assaiante, May 9, 2021.
  1. Steve Assaiante
    Steve Assaiante New Member
    May 9, 2021
    I have a 78 Camaro and my window seals leak I have replaced them with new ones from classic industries the windows do not meet the seals right I've tried Adjusting the doors and windows If anyone has any ideas please let me know thanks
  2. CDesperado
    3,646
    96
    Oct 1, 2004
    Dallas Texas
    Pictures would help, but you may need to add some extra foam gaskets between the window frame and the seal.
  3. Steve Assaiante
    May 9, 2021
    I posted a picture not sure if you can see that well I'm not sure how that would work because the seals lock into a channel
  4. ULTM8Z
    ULTM8Z Veteran Member
    9,998
    846
    May 19, 2000
    Los Angeles
    I've found that I had to put spacers/washers behind the weatherstripping channel in various locations to get the curvature to match the window better. Just 70s manufacturing quality...
  5. CDesperado
    3,646
    96
    Oct 1, 2004
    Dallas Texas
    Thats a really interesting idea. Im about to have to pull my Passenger side seal down and do something because I have about a 1/8" gap between the window and the seal. So Im assuming you put the spacers between the inside (upwards-facing) window weather strip channel and the bottom (downward facing) area of the roofline?
  6. ULTM8Z
    9,998
    846
    May 19, 2000
    Los Angeles
    That's correct. Yeah I had about 1/8 gap as well... the roofline curvature just didn't match the window very well.
  7. 73 Z
    1,159
    73
    Jun 9, 2007
    Los Angeles, Ca
    Looks like you need some more tedious window & door alignment
    Lets see a photo from a few feet back from door
    GoldenOne7710 likes this.
  8. CDesperado
    3,646
    96
    Oct 1, 2004
    Dallas Texas
    To fix my problem (which was really bad on the Passenger side) I added an extra 1/8" strip of weather adhesive to the back side of the weather strip channel. The window now sits snugly against the weathstripping and I was lucky to not have to re-align the windows.
    So it goes like this:
    Body of Roofline
    1/8" thick weatherstrip (adhesive backed) - This is what I added
    1/8" thick weatherstrip (adhesive backed) - This is what I had already attached to the channel and was the OEM/factory thickness.
    Weather Strip Channel
    3M Super Black Weatherstrip Adhesive
    Weatherstrip
  9. Steve Assaiante
    May 9, 2021
    Thanks for the advice was the weatherstripping rubber or foam and were did you buy it from Thanks Steve
  10. CDesperado
    3,646
    96
    Oct 1, 2004
    Dallas Texas
    Its basically a specific type of closed cell foam, which I believe is the neoprene type. I'm drawing a blank about that, so I would need to go check. (People make this closed cell foam out of polyethylene, neoprene, and some other type of foam rubber. I bought multiple products and compared the texture, density, and absorption tests. It was clear that one product more closely resembled what originally was on the car. I can take pics if you like.)
    Btw, I found a product at Lowe's that looked sort of similar, but the Auto-grade products looked to be better with better quality foam. I dont know how to explain it, but you could feel the difference in texture and weight, and they were basically the same price.
    Anyway... I bought this foam in a giant roll, because I cut all my own weatherstripping pieces. I also used this to cut a gasket that rests in between the body of the car and the chrome B-pillar trim and a few other things. I ended up with a lot over, but I've used it in various ways around the house and some projects here and there. It's been handy and I have used a lot of it.
    But it looks exactly like this:
    https://www.amazon.com/dp/B071RDDC2...d_r=5ec586ca-c698-4477-b784-aa5d4608c038&th=1
    I think the Lowe's stuff (that I opted out of) was more like this - The Low density seems fine until you look at a different product side by side.
    https://www.amazon.com/fowong-Low-D...t=&hvlocphy=9026794&hvtargid=pla-841410897524
