Window seal leaks
Discussion in 'Interior Restoration' started by Steve Assaiante, May 9, 2021.
  1. berg2695
    berg2695 Veteran Member
    568
    213
    Nov 13, 2011
    AUBURN, WA
    20210519_121047.jpg The weatherstrip channels have slotted holes. Maybe there is some room to adjust them outward a little.
  2. CDesperado
    3,672
    101
    Oct 1, 2004
    Dallas Texas
    Ok, so there should be two gaskets in that pic:
    1. a gasket between that piece, and the water rail (which isnt in your pic)
    2. A gasket between the water rail and B-pillar/Body
    And then 3M Super Black to get the weather strip into that channel.
    Also, buy these... it will help a LOT. That really wide tool is what I used to ensure that the edge went into the channel without tearing.
    https://www.amazon.com/Interior-Fas...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
  3. badazz81z28
    21,031
    1,484
    Alabama
    You should be able to get it as close as it can be by just adjusting the window glass....I don't see the need to have 1/4" of foam under the tracks...
  4. CDesperado
    3,672
    101
    Oct 1, 2004
    Dallas Texas
    There is supposed to be 1/8" of foam between the body of the car and the window channel. It came from the factory like that.
  5. mrfleet12
    mrfleet12 Veteran Member
    953
    593
    Aug 8, 2014
    West of Chicago IL
    Does anyone have pics of properly adjusted windows, would like to see how these should look when they fit correctly.
  6. 73 Z
    1,171
    73
    Jun 9, 2007
    Los Angeles, Ca
  7. 73 Z
    1,171
    73
    Jun 9, 2007
    Los Angeles, Ca
  8. 73 Z
    1,171
    73
    Jun 9, 2007
    Los Angeles, Ca
    About an 1/8" tighter at B/P on rt side,
    Better than GM
  9. mrfleet12
    953
    593
    Aug 8, 2014
    West of Chicago IL
    Thanks, way better fit than mine, what brand of seals are you running?
  10. CDesperado
    3,672
    101
    Oct 1, 2004
    Dallas Texas
    MetroMold Seals are generally considered better than SoffSeal, both in quality and heat resistance. But if you live in a temperate climate, SoffSeal is probably fine.
    There is a 3rd vendor in the market now - I think it is called Steele Rubber Products, but I dont know of anyone who has tried their product.
