Windshield Eyebrow Repair/Restore
Discussion in 'Tips 'n' Tricks Topic' started by badazz81z28, Jun 28, 2020.
  1. badazz81z28
    18,226
    853
    Alabama
    So I have these broken 70 only eyebrows I need to fix since I can find is broken ones...What are some tips to get a good bond/repair and sandable to smooth it all out and look great!
    Thanks,
  2. Camaro Tim01
    Camaro Tim01 Veteran Member
    227
    38
    Jun 8, 2020
    Bradenton, Florida
  3. badazz81z28
    18,226
    853
    Alabama
    Well, I’m no expert, but in-process using JB Weld Plastic filler epoxy black. Seems to work ok. Wish I had a before picture...cracks and Knicks out of it.
  4. COPO
    19,090
    1,367
    I use liquid (not gel) super glue. Then as quick as you can cover it with baking soda. Let it sit for 15-20 sec and brush away the excess baking soda. It’ll harden like a rock and can be built up in layers and sanded or filed then prime and paint.
    Revin likes this.
  5. badazz81z28
    18,226
    853
    Alabama
    I’m no expert, but only if you saw it before! 56EBC0B9-52DD-4AD4-88AC-8525B179CAA1.jpeg
    BillyDean7173 and dave@ztech like this.
  6. COPO
    19,090
    1,367
    Nice job.
  7. badazz81z28
    18,226
    853
    Alabama
    2EC2D701-21DE-436B-8A58-E855A839E66D.jpeg 50B6B131-6949-45FC-9666-73254550F59A.jpeg
    second one done! Need to drill a new hole though.
  8. dcozzi
    dcozzi Veteran Member
    3,580
    732
    May 1, 2002
    Phoenix, AZ
    Looks good. Did you use the JB Weld? I was going to suggest black ABS glue.
    I figured super glue will get brittle over time from constant heating/cooling.
  9. indyjps
    indyjps New Member
    May 27, 2004
    Oswego IL
    If the crack closes up tight, on the front, i use a coat hanger and propanr torch. Get a helper to hold the crack tight (um), then heat the coat hanger loop in the torch and melt across the crack on the backside. You can try using a slice of the same material to melt in as well.
    The crack wont disappear from the front, but it also wont mess up any graining or texture in the front.
  10. badazz81z28
    18,226
    853
    Alabama
    I used JB black Plastic Urethane gap filler to fill the scratches and cracks. I used JB plastic epoxy fix the broken parts with splices. Lots of sanding to smooth it all out. Used filler primer and SEM trim paint.
