Wix XP Oil Filter
Discussion in 'The BS Topic' started by Flynt, Aug 13, 2020.
Tags:
  1. muscl car
    23,052
    1,554
    Jul 8, 2001
    SoCal High Desert
    My engine builder reccomends Wix racing or Moroso oil filter and for further protection I'm running these pre screen filters
  2. Flynt
    Flynt Veteran Member
    860
    14
    Jul 9, 2003
    Alabama, USA
    Thank you for the information.
  3. Dave Nelson
    Dave Nelson Veteran Member
    5,072
    3,981
    Dec 19, 2003
    Vineland N.J USA
    Rock Auto was the cheapest.
  4. Knuckle Dragger
    16,184
    2,524
    Nov 2, 2002
    Waddell AZ
    I checked 7 different Wix filter numbers in my stock today. Six were made in USA the other in Mexico.
    muscl car likes this.
  5. Todd80Z28
    11,855
    423
    Jun 11, 2002
    Northern VA
    Can you end up with less filtering by using more filtering? I assume he suggests the racing filter because they filter a bit less- and drop less pressure while doing so, meaning more oil for the engine. If you put more filter in front of what surely is a high volume pump on your engine, do you just force into bypass more?
  6. muscl car
    23,052
    1,554
    Jul 8, 2001
    SoCal High Desert
    This is from Moroso ......
  7. Lowend
    15,978
    1,004
    Mar 25, 1999
    San Jose, CA, USA
    I really can’t see the reason for this. Why not just build the filter properly?
  8. BLUE72CAMARO
    BLUE72CAMARO Veteran Member Lifetime Gold Member
    4,883
    270
    Mar 15, 2004
    Bunker Hill, IL
    My only guess is it would make any large particles obvious when you change the filter, where a normal design filter hast to be cut open to inspect it for chunks.
  9. muscl car
    23,052
    1,554
    Jul 8, 2001
    SoCal High Desert
    Exactly !!!!! , a easy way to check for engine damage
  10. Mike N
    2,947
    659
    Jan 13, 2002
    Spencerport, NY.
    And at the end of the day if your engine still has the stock bypass in place, your choice of oil filter is basically irrelevant.
