Wobbling Right Rear Wheel
Discussion in 'Troubleshooting & Diagnosis' started by Robert M Mrozek, Sep 5, 2020.
  1. Robert M Mrozek
    Robert M Mrozek Veteran Member
    110
    15
    Oct 4, 2016
    1970 Camaro. 10, 8.5" bolt rear axle. Rear tires are P275/40R18. Was waved down by someone to say my car looked great and that my right rear wheel was loose. I did not feel any vibration while driving not did i hear any wheel bearing grinding (but the exhaust and car is quite loud). I checked the lug nuts and nothing loose. I put rear axle on jack stands and watched the wheel spin and it is definitely wobbling/waving. Just the right wheel. Took off wheel and I can see the brake drum wobbling as well so it's not a bent rim. I have new rims, tires and I drive it normally. I have not experienced any hard impacts or accidents. Thinking either bad wheel bearing or bent axle shaft. Any suggestions on how to narrow the root cause to axle shaft or bearing? Thanks!
    Links to youtube video
  2. Knuckle Dragger
    15,866
    2,247
    Nov 2, 2002
    Waddell AZ
    Going to be the axle. A bad bearing in the rear won't wobble. Oh course when you replace the axle you'll want to replace the bearing and seal at the same time. If I was going to change one axle I'd go ahead and do both, all kinds of stronger options out there now.
    Pull the brake drum off and watch the axle flange to be sure. Make sure you don't touch the brakes with the drum off or you'll need to repair the wheel cylinder too. That movement in and out is fairly normal.
  3. tom3
    tom3 Veteran Member
    12,947
    754
    Aug 1, 1999
    ohio
    I'd first try another wheel on that axle and look for runout. And make sure the axle face and inside mating face of the drum is clean.
    Cast iron doesn't like to bend but I guess for that little bit it could have?
  4. Zspoiler
    Zspoiler Veteran Member
    3,717
    342
    May 6, 2012
    Federal Way, Washington
    I also would check the wheel first .That is the easiest to replace then go from there
  5. biker
    biker Veteran Member
    2,144
    768
    Dec 7, 2014
    Tighten a couple nuts down on the drum before you spin it just to make sure the drum isn't sagging away from the axle face, but it does behave like a bent axle.
    Car sounds great too.
  6. rocket dawg
    rocket dawg Veteran Member
    382
    46
    May 5, 2015
    Grand Rapids Mi
    Pull the drum off and check for rust or dirt build up between the axle and the drum, same if its a rotor also.
  7. Jim269
    Jim269 New Member
    Apr 1, 2020
    I had the exact same problem on the left side. Replaced the axle/bearing/seal and problem gone....
  8. Robert M Mrozek
    110
    15
    Oct 4, 2016
    Thanks to all for the advice. Great thread on how to troubleshoot this type of issue. Ended up being a bent axle shaft. Took it in to the Ring and Pinion Shop in Clinton Township, MI (great work!) and got new Moser 28 spline axle shafts and new bearings. Also had it in to change the ring and pinion from a 4.56 to a 3.42.
  9. Z28PILOT
    Z28PILOT Veteran Member Lifetime Gold Member
    2,077
    52
    Oct 8, 2009
    Emerald Isle , NC
    3.42 should be a bit more relaxing to drive....LOL
  10. mallard
    mallard Veteran Member
    882
    229
    Oct 3, 2013
    SK, Canada
    And thank you for posting how this turned out. So few do and I like hearing the end results.
    Robert M Mrozek likes this.
