? wrong outer window felts
Discussion in 'Troubleshooting & Diagnosis' started by Chuck71RS, Nov 20, 2020.
  1. Chuck71RS
    1,624
    276
    Nov 24, 2012
    Houston, Texas
    Poor word choice by me. When I said Velcro was used, it was only the two that have the fuzzy felt (in the middle and at the back). The front panel support only is made as the other two but without the curved part that the felt goes on
  2. Chuck71RS
    1,624
    276
    Nov 24, 2012
    Houston, Texas
    Still a mystery. Same condition for both doors
    Outer felt style is correct by not having the chrome bead. (outer door top edge has reveal molding).
    Two inner window guides look like those in Camaro videos. None are bent and fully inward (the guides are against the door.
    The Velco fuzzy felt on the inner guides is a tad thinner then the original
    Glass adjustment: in-out fully inward, glass is level, front-rear looks even. Seals still at Metro Molded Parts
    With 1978 door panels on, tension on the glass is more sever than before. Prevents rolling up
    Have I missed anything that affects clearance between outer and inner felts?
  3. 73 Z
    1,124
    69
    Jun 9, 2007
    Los Angeles, Ca
    My window supports are different they don't curl/loop at the window.
  4. TommyRS70
    TommyRS70 Veteran Member
    1,286
    146
    Jan 31, 2004
    KY
    The 70-71 retainers are different than 72 and up. These are 72 design...
  5. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,907
    136
    Jul 31, 2001
    Ft. Lauderdale, FL
    The one in front just serves as a sorta hook to hook the inside edge of the door panel on. The middle one and the back one have the fuzzys.
    Those can and do have the ability to be bent at just the right angle you need. I used a hammer tap them and put them back on and test them. With the whole glass adjusting thing the body shop didn't even get them close, and I didn't want to pay them another 20hrs to do this.
    After trying Metro..Softseal...and some other no-name roof rail seals, I ended up buying GM stuff from Year One so I could shut my doors with the windows up without having to slam them. The price hurt bad, but they are very squishy and soft and compress so much more than any of the repo roof rail strips..
    I did use Metro on the rest of the car with no issues. But those roof rail glass seals? No way.
  6. Chuck71RS
    1,624
    276
    Nov 24, 2012
    Houston, Texas
    My retainers at the end curve back under. Must be the right ones then
    I will consider doing this as a last resort. No idea though what the needed angle is.
    Both doors closed pretty darn good using Metro door and window seals. Had to remove A LOT of material from the front ends of both. To do most of this the ends were cut off. Also the surfaces crumble. Metro is sealing the ends and will reattach. The window ends will be attached to seals treated with a Metro substance used on Corvette seals to reduce friction
    I WONDER: The outer felt (replaced with after market during this rebuild) style looks correct but is something wrong the way it was made?
