WTB 70-71 Parking Brake Switch
Discussion in 'Swap Meet Section' started by Adams, Oct 19, 2020.
  1. Adams
    Adams Veteran Member Lifetime Gold Member
    929
    27
    Jul 16, 1999
    From Motown (still in the blood), live in Houston
    I am in need of a parking brake switch for a 70-71 Camaro that grounds to make circuit with the warning light on the dash.
    Looked and called NPD, Camaro Central, OER, Rick's, Classic Headquarters, Classic Industries, AC Delco, M&H, InLine Tube, SS396, Rock auto, eBay, Amazon. Coming up crickets for this two year only part. Anyone have one for sale?
    Original GM part no was 3983909. I will take anything that fits.
    Saw someone posted this excellent pic in the past.
  2. shanghai Kid
    shanghai Kid Veteran Member
    280
    169
    Jul 5, 2010
  3. Adams
    929
    27
    Jul 16, 1999
    Long gone. I saw that too. Add your personal details and click "Buy It" and it says it is not available. :(
  4. badazz81z28
    20,392
    1,337
    Alabama
    They are tough to find....Tossed mine not even thinking about it! Bought one on Ebay after an exhaustive search!
  5. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,709
    907
    May 21, 2014
    Hutto, TX
    Adams likes this.
  6. flht99b
    flht99b Veteran Member
    836
    274
    Nov 28, 2014
    Knoxville, TN
    Didn't realize that switch is 70/71 only. Guess I should start looking for a spare. I find it hard to believe that switch did not find it's way into similar years Nova's, Chevelle's and full size cars.
  7. badazz81z28
    20,392
    1,337
    Alabama
    The parking brake assembly body is different requiring a different switch.
  8. Adams
    929
    27
    Jul 16, 1999
    The mounting plate is not the same 70-79 where the anchor pin is and the pin on the switch changed 72 and then again in 76 from with I see.
    70-71 round single pin
    72-75 flat single pin
    76-79 two flat pins
    Can't believe with all the 2nd gens nobody repops any of these! 67-69 yes, 81-up yes. Everything in between nada nunca.
  9. badazz81z28
    20,392
    1,337
    Alabama
    If I understand you right, I don’t think you’re correct...the switch from a later year won’t physically fit. The body is different...because the brake assembly is different.
  10. Adams
    929
    27
    Jul 16, 1999
    parking brake assembly is same from 70 to 81 with the exception of the pin configuration on the switch and the anchor pin on the bracket. Brackets are a little different but mount with the same bolt. Left is 70-71, Right is 73-76. They changed sometime in 72.
