WTB: Floor shift tilt steering column (73 Camaro)
Discussion in 'Swap Meet Section' started by ecrump06, Nov 9, 2016.
  1. ecrump06
    ecrump06 New Member
    21
    Aug 5, 2016
    newman, california
    Looking for a floor shift tilt steering column for 73 automatic Camaro. Thank you.
  2. nobreaks254
    nobreaks254 Veteran Member
    519
    13
    Jul 14, 2007
    aberdeen, SD
    I have a tilt column from an 81 Trans Am if that will work for you
  3. ecrump06
    ecrump06 New Member
    21
    Aug 5, 2016
    newman, california
    I'll have to do some research. I'm not sure if they are interchangeable.
  4. ALLZS
    ALLZS Member
    31
    Nov 11, 2007
    ST LOUIS MO
    I have one removed from a 72
  5. 72Heaven
    72Heaven Veteran Member
    1,756
    Jun 4, 1999
    Topeka,KS,USA
    The '81 has a "double D" shaft, interchangeable IF you also grab the intermediate shaft, now there was also a change in wiring, so you'll also need a cancelling cam/ignition switch wiring or do
    some basic wiring changes, I'd go for the early one to save the trouble...but it can be made to work.
  6. wasp
    wasp Member
    87
    10
    Mar 8, 2009
    Milpitas, CA
    If you are changing to a tilt column make sure to get the correct intermediate shaft or your steering wheel will be 90 degrease off. I will try to post a picture of the differences in the shafts this weekend. 70- 74 firebird steering columns also work.
  7. ecrump06
    ecrump06 New Member
    21
    Aug 5, 2016
    newman, california
    Thank you everyone for the replies. I had no idea about the intermediate shaft. I really underestimated the price of restoring a car hahaha.
  8. nobreaks254
    519
    13
    Jul 14, 2007
    aberdeen, SD
    I have the shaft for the 81 if that matters to you
  9. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,653
    1,073
    Mar 27, 2016
    NY
    Yes the price for some parts is through the roof , and tilt is one area, Flaming River has the correct parts that will fit, just pricey , however no guess work , I am saving up for one of them , as some of the used ones are almost the same price
  10. 72Heaven
    1,756
    Jun 4, 1999
    Topeka,KS,USA
    You can index the new shaft (on the early cars) by loosening the lower 7/16 bolt on the steering box rag joint, and turning the wheel where you want it and re-tightening the bolt. This process may involve jacking the car up and down to get at the bolt and it may be a pain in the a$$, but the "wrong ones" will work.
    brooksman9 likes this.
