WTB O Rocker Arms Set
Discussion in 'Swap Meet Section' started by clm69z28, Dec 10, 2020.
  1. clm69z28
    clm69z28 Veteran Member
    304
    Oct 29, 2011
    encinitas ca
    Looking for a complete set of O rockers. Let me know what you have. Thanks.
  2. Silver75
    Silver75 Veteran Member
    547
    18
    Feb 27, 2002
    Georgetown, PA
    Are you looking for new or would a used set suffice?
  3. clm69z28
    304
    Oct 29, 2011
    encinitas ca
    New would be preferable, but used would be ok but they would have to be in pretty good shape.
  4. Silver75
    547
    18
    Feb 27, 2002
    Georgetown, PA
    I have a used set. I will get you pictures of what I have.
  5. COPO
    21,095
    2,616
    Because of so many that were stamped out, new or used will not all equal 1.5 ratio which will lose you HP.
  6. 70lt1z28
    4,440
    1,057
    Oct 3, 1999
    Beavercreek, Ohio, USA
  7. COPO
    21,095
    2,616
  8. clm69z28
    304
    Oct 29, 2011
    encinitas ca
    Dave, thanks I did see these. Was looking for something a little fresher. I wasn't sure about the O orientation either.
  9. 1980RS
    1980RS Veteran Member
    5,580
    1,866
    Jun 17, 2006
    MN
    Don't worry about a loss of power with stock rockers. On the dyno last year, we did a test and it was less than 5hp between the stock rockers and roller rockers you will be fine with them. The best aftermarket "stock" rockers I have found are the Elgin or Summit rockers. I know for a fact that the Summit ones are USA made, if you can't find the 0 ones the Summits will work for you.
  10. clm69z28
    304
    Oct 29, 2011
    encinitas ca
    In the interests of time, I went with the Elgin rockers and if I come across a good set of the O rockers, then I'll swap them out.
