WTB: Power Steering Box Cast # 5691676
Discussion in 'Swap Meet Section' started by CamarosRus, Aug 8, 2017.
  1. CamarosRus
    CamarosRus Veteran Member
    8,550
    153
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Wanted: Power Steering Box 5691676
    for my 73' Camaro Project
    In good working condition NOT full of water
    I can clean grease from outside
    Contact my below Email
    or text 253-263-5190
    Chuck Sharin
    [email protected]
    still in Auburn, WA
    no secrets here, come and visit anytime
  2. CamarosRus
    8,550
    153
    Feb 16, 2000
    bump
  3. ALLZS
    ALLZS Member
    31
    Nov 11, 2007
    ST LOUIS MO
    chuck I have a real nice one with pitman arm from a 73 Camaro
  4. boardog
    boardog Veteran Member
    964
    21
    Dec 8, 2006
    north ga
    chuck, I have one if needed. looks like allzs has what you need. i am keeping my pitman arm.
  5. CamarosRus
    8,550
    153
    Feb 16, 2000
    I had a 5691676 casting steer gear from a 68-69 (??) Nova Subframe
    I parted....
    I'm hoping this box is correct for my 73 application with same casting number ?????
  6. 70lt1z28
    4,490
    1,095
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Box is the same but the pitman is different. The steering ratio will be different. Casting numbers had no bearing on the internal ratio. There are no external numbers that reference the ratio.
    70-camaro likes this.
  7. CamarosRus
    8,550
    153
    Feb 16, 2000
    Dave, I'm sure its on this site...........WHAT year(s) of Gear Box do I want for
    my 73 project....................IF NOT this 68-69 Nova Box ??????????
  8. 70lt1z28
    4,490
    1,095
    Oct 3, 1999
    The 68-69 box will physically fit, but the steering feel will Nesbit different from stock, but you may not notice unless you did a quick side by side comparison. Is your 73 a Z or base model? They had different ratios with the Z having a quicker ratio (less turns lock to lock) and better road feel. The best GM box is considered to be a 76-77 Trans Am WS6 box. It had the non-metric hose fittings so the hoses would bolt up and the 13/16 splines for the same rag joint. The problem is you can't tell by the box numbers (casting or end cap) what you are getting cause they are all the same. Next best is generally considered to be the 70z box which is actually different than a 71 z box. But with anything 70z as you I'm sure know good luck finding and paying for it.
  9. CamarosRus
    8,550
    153
    Feb 16, 2000
    Dave, I'd like to have a "correct" steer gear for my 73 LT project............
    What YEARS were same ratio as 73 LT (NOT Z28)
    Thanks
  10. 70lt1z28
    4,490
    1,095
    Oct 3, 1999
    Not sure if this helps:
    http://www.chevelles.com/techref/ftecref29.html
    But it does provide some info.
    I think what the spreadsheet says is your car had a WS ink stamp on the aluminum cover indicating the gear set. So this is the gears wryly are trying to match for the same steering feel.
