X-pipe sound
Discussion in 'Engine Topic' started by arnies81camaro, Oct 1, 2013.
  1. arnies81camaro
    arnies81camaro Member
    59
    Aug 20, 2011
    groveland,ma.
    I have a 3" x-pipe exhaust system with flowmaster mufflers 40 series, Is it the x pipe that is making the raspy sound between 2-3 thousand RPMS? how would it sound if I went to an H-pipe and eliminated the x-pipe? it's a 70 Camaro 350 with AFR heads, hooker super comp headers,
  2. loyal guardian
    loyal guardian Veteran Member
    697
    Aug 28, 2013
    helena mt
    I got a 79 z with a 350, summit headers and glasspacks, with pypes xpipes inbetween, all 2.5 respectfully and i like them. Each type of pipe has a different use, between manifold pipes (2 to 1 down), x pipes, H pipes and straight pipes. From my understanding and i could be wrong but H pipes were the original x pipes. Do reseach and find what u like best. Here are some help pages
    http://www.nastyz28.com/forum/showthread.php?t=233682
    http://www.stevesnovasite.com/forums/archive/index.php/t-33539.html
    http://en.m.wikipedia.org/wiki/Aftermarket_exhaust_parts
    http://www.superchevy.com/technical/engines_drivetrain/exhaust/0505phr_exh/
    http://www.boyleworks.com/ta400/psp/exhaust.html
  3. Lobsterbak
    Lobsterbak Veteran Member Lifetime Gold Member
    152
    Aug 31, 2007
    Adirondack, New York
    I wouldn't blame the x-pipe, maybe the blowmasters? I have 2.5" pypes violators with an x pipe on my T/A 487 CI with Hooker full length headers and mine isn't raspy at all.
  4. woody80z28
    5,578
    64
    Sep 8, 2004
    walton, ny usa
    X-pipes actually smooth out the exhaust tone compared to divorced duals. I'll bet it's the mufflers.
  5. muscl car
    22,192
    990
    Jul 8, 2001
    SoCal High Desert
    When I installed my 3"dia x-pipe it actually quieted down the exh note substantially
  6. ProStreet383
    ProStreet383 Veteran Member
    2,106
    9
    May 23, 2007
    MD
    X pipes produce a higher pitched almost indy car type of sound. They tend to reduce or eliminate the raspy sound of certain mufflers and reduce the sound level.
    Here is my car for example. 1 7/8" super comps into 3" exhaust with small 12" length Borla sportsman mufflers and an X pipe. It dumps at the diff. This is WAYYYYYYYYY quieter than it used to be with the straight exhaust and flowmaster 40 series and also when i had bullet mufflers. You can talk comfortably in the car now.
    http://www.youtube.com/watch?v=vIQqzKXRtZw
  7. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    It's caused from the resonance frequency of something in the exhaust. Either a length of pipe, the muffler, etc.
    When the frequency (tone) of the exhaust matches the resonance of another piece in the exhaust system it causes odd noises to occur. It's actually very similar to how any wind instrument works.
    Have you ever heard of resonators? That's what they're for.
    http://auto.howstuffworks.com/muffler4.htm
  8. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,563
    22
    Feb 11, 2009
    Kentucky
  9. muscl car
    22,192
    990
    Jul 8, 2001
    SoCal High Desert
    3" exh with magnaflow x-pipe ,Spintech mufflers and 3" tails ... no resonance or loud interior noise
    [youtube]/cVhQoO9NPQo[/youtube]
  10. 5spd540
    12,388
    16
    Sep 19, 2009
    Guyton, GA
    I love the sound of spins
