yet another cam question
Discussion in 'Engine Topic' started by meangreen73, Mar 10, 2009.
  1. meangreen73
    meangreen73 Veteran Member
    719
    Feb 16, 2008
    Pittsburgh
    ok the other day i put a post up about the the crane cam 100172. Well i tried to order it and everywhere i checked its either discontinued or on back order. my question is does anyone know of a cam that is similar to the 100172? I was lookin at the Lunati 00016LK, has anyone tried it or know of a cam similar to the 100172? and im runnin a 350 with 194 heads (vortecs eventually) and possibly a stock torque converter or a 2400 stall. I just want a mild built 350 with a good sound like what the 100172 would give me.
    Heres the specs for the crane 100172 .450 lift, 272/272 Adv duration, and 218/218 duration at .50 lift.
    and heres the link for the lunati.
    http://store.summitracing.com/partdetail.asp?part=LUN%2D00016LK&autoview=sku
    Thanks
  2. meangreen73
    719
    Feb 16, 2008
    Pittsburgh
  3. Led Zep
    Led Zep Veteran Member
    575
    33
    Mar 13, 2008
    Ky
    Crane went out of business.I doubt their will be any backorders.
  4. meangreen73
    719
    Feb 16, 2008
    Pittsburgh
    yea thats what i heard thats why im lookin 4 an alternitive
  5. docwilcar
    docwilcar Veteran Member
    172
    Jul 19, 2008
    WABASHA, MN
    That lunati cam will not sound like the 100172 and will be milder because of the 110 LSA vs. the 106 of the Crane but will still be a good cam for you. Go to fastengineparts.com or performanceparts.com and see if they have any. The "cam only" part number is 10017 so you might do a google search for that too. Those cams are around, you just have to do some searching on amazon, ebay, google, etc. The 172 cam is a great cam for a mild 350 that has a small duration with a big cam sound. Should make around 14" of vacuum at 1000 rpm and 11" at 850 rpm. Made this in a friends 260 hp crate motor which is only around 8-1 cr. You may need a 2400 stall with this cam. Although Crane has shut there doors, they are several companies looking to buy them.
  6. tom3
    tom3 Veteran Member
    13,330
    940
    Aug 1, 1999
    ohio
    Amazes me that they can get that much lift with 218 deg duration. Be a good cam for a medium performer/driver.
  7. loudvolvo
    loudvolvo Veteran Member
    363
    Sep 24, 2008
    Shelbyville, Ky
    i had the bracketmaster II cam p/n 00017 i liked it alot, good idle and plenty of lowend torque. my buddy was gonna get one but the backorder date from summit was the begining of april at the time
  8. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    The advertised duration is 2 weeks long, that's how.
    The 218* duration is at .050" lift (not .50", as I'm sure that was a typo on the OP's part).
  9. Simon@London
    [email protected] Veteran Member
    1,244
    Feb 16, 2009
    London Ontario
    Here is your Crane cam with 3 in stock.
    http://cranecams.com/?show=browsePa...-400 C.I.&partNumber=100172&partType=camshaft
  10. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Crane 100172 is the same-ish enough as the comp 268 HE.
    Comp just charges more for a less durable part.
    Also check SpeedPro, Sealed Power, Wolverine etc.
