Your Engine Specs and Data
Discussion in 'High Performance Modifications' started by vegas1974z28, Apr 22, 2010.
  1. Plant Engineer
    Plant Engineer Veteran Member
    407
    111
    May 17, 2017
    Fort Mill SC
    Year:
    1979 dolled up like a 1970 RS. 3250 lbs.
    Engine:
    427 CID 11:1 compression standard bore Gen 6 + BBC built on a fresh ZZ454 block
    6.535" Molnar H Beam Rods
    Callies 3.76" Forged Steel Crankshaft
    RaceTec 35CC dome forged pistons
    AFR 265 heads with hydraulic roller compaitble 185 lb on seat PAC springs 357 CFM at .650"
    Lunati 240/245 @.050" .612" Hydraulic Roller with Howards/Morel rollers
    Comp gold rockers
    Holley HP sequential MPFI with 1000 CFM throttle body. 48 lb injectors
    Holley dual sync distributor
    Summit 280 LPM in tank fuel pump running at 45 PSI.
    Holley water/methanol injection
    Dry Nitrous PWM controlled
    Summit electric water pump
    8" vacuum at idle. Purrs like a kitten
    Transmission:
    Richmond 5 speed S/S .78 OD
    Mcleod Dual Disk RXT clutch
    24 lb Mcleod flywheel
    Rear End , exhaust and brakes:
    Strange 4" driveshaft
    Strange Dana 60 with bearing adjusters
    4.10 gears
    Strange disk brakes in the back. Stock in front
    Hydroboost
    Powerlock limited slip. This is a street car after all
    35 spline Strange axles.
    2" primary hedman headers X pipe mandrel bent 3" bends sectioned and fully welded all the way back.
    15X14 wheels in back 29x18x15 MT tires.
    Dave Nelson likes this.
  2. pitt16
    pitt16 Real 26/28
    32
    12
    Jan 26, 2007
    Spring Hill,Florida
    Year,weight
    1978
    Stockish
    Dyno (bench)
    400ish
    Engine
    355,10.5-11:1,
    Stock crank and rods
    Forged SRP domed pistons
    Comp 306s cam. 260 duration @.050
    .555 solid lift
    Cast 76cc heads ported and with 2.050/1.60 valves (AFR’S in future)
    Holley strip dominator single plain
    Holley 830 annular discharge carb
    Exhaust
    1 5/8 with 3” collectors
    Flow masters
    2.5” out the back
    Rear end and weight movement
    Narrowed 9” 31 spline spool chassis engineering ladder bars aluminum back 1/2 15 gallon fuel cell and two batteries in trunk
    Suspension
    Stock front,
    Aldin American coil overs with back 1/2 kit
    Pizza cutters up front 4”pro stars
    30x15x15 rears on 12” pro stars
    Trans.
    Th350 b&m trans pak
    3500 10 stall
    Times
    Non official but fast as far as I can feel
  3. newschool72
    newschool72 Veteran Member
    1,185
    Feb 25, 2011
    forsyth,ga
    1972
    Pro built billet 2004r trans
    8.5 10 bolt, 3.42 , summit axles, GM posi.
    Homemade triangulated 4 link, single adj coil overs, QAD coilover conversion on front (single adj ), Hotchkis front and rear sway bars.
    2010 all aluminum LS3, hand ported 317 heads, .098 MLS head gaskets, 9.2 comp, bullet racing custom turbo cam, bushing upgraded rocket arms, trickflow pushrod, FiTech 1200pa TB, 80mm billet turbo.
    400+hp ago , it ran 11.65 at 119 NA. On 12.5 psi boost bench dyno 900hp flywheel. Should make 750+rwhp on current tune. No track times yet, but I hope to make a single hail Mary pass this fall. No cage :eek:
  4. DB Z28
    DB Z28 Veteran Member
    639
    90
    Nov 30, 2003
    Fond Du Lac
    Year
    ,Weight
    1979 Z28 Camaro
    Weight 3465
    Dyno Crank
    711.hp 611 Tq @ Flywheel
    Engine
    427 LS-7 built by Wegners
    11.7 cr
    Stock LS-7 block
    Callies Draganslayer Crank
    Callies compstar rods
    ATI balancer
    Mahle Pistons and ring pack
    Modified LS-7 heads by Wegner
    Ferrea valves
    3/8 pushrods
    PAC valve springs
    Lunati Cam .600 lntake .624 EX Hydraulic Roller
    115 Lobe separation
    Morel rollers
    GM LS-7 Aluminum intake for a 4150 flange, ported , 2in spacer
    Fast Billet throttle body By Accufab 2000cfm
    Stock Rocker arms with bushings mod
    Bosh injectors
    Water pump, Steward
    Stock dry sump with Peterson Oil tank
    Holley Terminator X Max EFI system
    Fuel system Twin Walbro GS 340 fuel pumps in tank. control by Holley with a aeromotive regulator in a stainless tank by ricks #8an line
    Exhaust
    Hooker Stainless headers 1 7/8 primary with 3in collector
    Stainless works 3 in with x pipe with Spin tech super stock 1000 mufflers with stainless works 3 in tail pipes
    Transmission
    TKO-600 by Liberty
    Bronze shift forks pads , internal Shift linkage upgrade
    Pro shifter
    carbon fiber blocker rings .Threaded front cluster bearing support
    With Quick time bell housing.
    Stock LS-7 clutch for now and flywheel
    Rearend
    Moser 12 bolt 33 spline axles, eaton posi
    4:11 gears,,
    Suspension & Brakes
    Global west upper and lower control arms
    PST coil springs with 2 in drop
    PST rear leaf springs
    Cal track bars
    Herb Adams Sway bars
    Koni shocks
    C-6 brakes by kore3 front stock trans am rear disks, Hydroboost
    Wheels
    Forgeline Rear 18x10 5.75 BS 285 40 18 tire nitto 555
    front 18X8.5 . 5in BS 245 45 18 tire nitto 555
    Still finishing up also no 1/4 mile times yet
    muscl car likes this.
  5. biker
    biker Veteran Member
    3,040
    1,280
    Dec 7, 2014
    My God.
  6. muscl car
    23,098
    1,592
    Jul 8, 2001
    SoCal High Desert
    Year , weight ...
    1972 Camaro SS
    3400lbs
    NHRA legal 9.90 cert 8 point cage
    Engine specs ...
    Shafiroff racing 427sbc 565 plus hp /575 tq
    Dart block splayed 4 bolt main caps
    4.125 bore / 4.000 stroke
    SSRE / Scat 4340 steel crank
    Scat 4340 6.000" H beam steel rods
    Mahle 9.5:1 forged pistons / 10.25 compression with 64cc cyl heads
    SSHHR Hydraulic roller cam 243/251 @ .050 598/602 lift
    AFR 210 Cyl heads
    7/16th studs
    Crane Gold race roller rockers 1.6 ratio
    Isky 8005A valve springs
    Edelbrock Super Victor intake
    1" tall Wilson tapered spacer
    750 Holley HP carb
    Hedman Huslr 1-7/8 headers
    Transmission ....
    Mike's Transmissions competition built TH350
    Reverse manual valve body w/transbrake
    9" custom built 4500 stall converter with anti balloon plates
    Suspension .....
    Front ...
    Calvert racing 90/10 shocks
    Moroso trick springs
    Rear .....
    Calvert 9 way adjustable shocks
    Calvert split mono leaf springs
    Calvert racing Cal tracks
    GM 10 bolt w/ 3.73 gears
    Eaton posi with 800ft lbs black stripe springs ( will be swapping to a fully built Ford 9")
    Tires /wheels
    Front ...
    Weld racing 15x4 Drag lites mounted on Mickey thompson tires
    Rear .....
    Weld racing 15x8 Drag lites mounted on 275/60-15 Drag radials
  7. biker
    3,040
    1,280
    Dec 7, 2014
    Enough already.
  8. nicholas_abbott
    nicholas_abbott New Member
    May 6, 2020
    Year weight
    1981 Camaro
    3450lbs race weight
    Dyno numbers
    Never dyno'd
    Engine
    383 CI
    10 to 1 compression
    Scat forged crank, H-Beam rods and SRP pistons
    AFR 195/60cc Eliminator heads
    Performer RPM Air-Gap
    Holley 770 Street Avenger
    Comp Cams Roller cam .510/.520
    Exhaust
    Hooker 1-3/4 ceramic coated headers, 3in collectors
    3" Dr Gas x-pipe
    3" in 2.5" out spintech split case mufflers
    2.5" side exit
    Rear and weight movement
    8.5" 10 bolt, welded axle tubes, 3.73 gears, Richmond Lock Right, Strange axles and c clip eliminators
    battery in trunk
    16 gallon fuel cell in trunk
    Suspension
    C/E Bolt-in SFC
    Jegs 6 point bars
    Home made Slapper bars, contacts spring eye.
    30 year old HD Sears front shocks
    30 year old HD Sears rear shoocks
    Stock springs all 4 corners
    MT 28x10.5x15 slicks
    Transmission
    Turbo 400 with a trans brake by jake
    5200-5400 converter
    Times:
    [email protected] 131.5mph in 4600' air
    [email protected] in 5000' air NA
