Your Engine Specs and Data
Discussion in 'High Performance Modifications' started by vegas1974z28, Apr 22, 2010.
  1. abshire1006
    abshire1006 Member
    51
    Jul 20, 2015
    Gueydan la
    Year weight
    1977 Camaro
    3300
    Dyno numbers
    Engine Dyno numbers 485/500
    RWHP 550
    Engine
    Blue Print engines SBC 396
    Blue print heads 195cc intake 64cc camber
    Cam comp cam 230 510/520 lift roller
    1.5 rocker
    edelbrock air gap intake
    holley 670 street avenger carb
    zex dry plate kit 150 shot
    MSD al6 ignition
    Exhaust
    Hooker long tube header
    flow master 40 duels with H pipe
    Rear and weight movement
    373 gear
    Easton built locking diff
    10 blot
    Suspension
    Rear coil overs
    sub frame connectors
    ladder bars
    Transmission
    B&M stage 3 turbo 350
    3500 Stall
    295/55/15 MT et street radials
    Times
    10.43 on bottle
    12.41 motor, with timing still pulled for no2
  2. 1700camaro
    1700camaro New Member
    Apr 30, 2016
    LasVegas, NV.
    Year weight
    1980 Camaro
    3100 race weight
    Dyno numbers
    Engine Dyno numbers 628hp @ 6,000/593 torque @ 4,600
    Engine
    434 CI
    11:1 compression, using 100 UL pump gas or E85
    Brodix Aluminum heads
    Brodix single plane intake
    850 Holley
    Comp Cams solid roller 266/272 @ .050, gross lift .688/.673 lobe separation 108
    Exhaust
    Headman Headers 1 7/8" primaries 3 1/2" collectors
    3" bullet mufflers
    4:11 spool with 10 bolt moser axles and c clip elim
    Dual batteries in trunk
    Fuel cell in trunk
    Suspension
    Smith Racecraft chromoly A-arms
    MOOG 6 cylinder springs
    QA1 stocker star, single adjustable
    6 point Bar
    Smith Racecraft assassin bars
    QA1 stocker star double adjustable
    Smith Racecraft split monos
    Hoosier 30x9x15 radial slicks (20 psi cold)
    Transmission
    Powerglide 1.76 1st gear
    8" TCI 5,800 stall convertor
    Best Time
    9.92 @ 136 detuned at 3,000' + above sea level. Car is only legal to be run at 10.00 & slower.
  3. stoney2677
    stoney2677 Veteran Member
    172
    Oct 6, 2007
    metuchen, nj
    Year weight
    1972 Camaro
    Stock weight
    Dyno numbers
    375 rwhp
    438 rwtq
    Engine
    454 30 over
    9.25:1
    702 heads with flat top pistons
    Comp 236/242 521/540 110lsa
    800DP
    Single plane edelbrock
    Exhaust
    Hedmans 2" pri 3.5 collector
    Pypes 3" with violators
    342 gear
    10 blot
    Suspension
    Stock
    275/60/15 DR
    Transmission
    keisler rs500 5 speed
    Times
    no track time
  4. CamaroGP
    CamaroGP Veteran Member
    691
    90
    Nov 10, 2012
    Summerfield, Florida
    Year weight
    1975 Camaro
    3300ish lbs.
    Engine
    468 BBC
    12.6:1 compression
    Wiseco slugs, H-beams, Bowtie crank
    Ultradyne custom ground solid roller
    Brodix BB2-Xtra heads 2.300/1.88 (gasket matched and bowls blended)
    Brodix HV1000 intake
    1150 HP Dominator
    Nitrous: Pro Race fogger and Big Shot plate (with separate fuel system)
    Exhaust
    Custom built 2-1/4" primary 4" collector
    Dynomax 4" bullet mufflers
    4.11 gear
    Ford 9" (Strange center section, Richmond gears and Detroit locker)
    Suspension
    Front: Moroso springs and drag shocks
    Middle: 14pt cage
    Back: Ladder bar and Aldan American coil overs
    Transmission
    Th400 Reverse pattern manual.
    Times
  5. 450bench
    450bench Veteran Member
    3,413
    154
    Feb 25, 2002
    memphis, tn-shelby
    Decked .030 1978 454
    Flat tops
    Vortec heads with a little work, changes over to adjustable valve train, 98cc chambers, about 10-1
    Weiand Stealth
    Slayer 750
    Elgin 226/226 521 521 with comp cams 1.72 rockers, cut on a 108
    1.75 headers
    Ls6 converter, th 400
    Stock mono leafs
    3.08 gear
    runs strong and you can drive it anywhere.
  6. LILRED496
    LILRED496 Veteran Member
    1,211
    Jul 14, 2008
    FLA
    555
    Flat top pistons
    10.7 compression
    .660/.660 [email protected] 110 lobe sep
    AFR 325s
    super victor
    1150 dominater
    2 inch headers
    4 mufflers with x pipe
    10 inch converter foot braked
    390 gears 10 bolt
    TH 350 with TH 400 drum and sprag
    135 psi cranking compression
    Factory power brakes with upgraded front discs
    Makes 800+hp on 90 octane
  7. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Weight 3100#
    Stock suspension
    Sears shoks
    Homemede slapper bars
    bolt in subframe connecters
    Six point roll bar
    Tranny
    350 turbo
    TCI manual valve body
    TCI 10" Superstreet fighter w/balloon plates
    Engine
    69 350 + 0.030"
    11:1 Z/28 pistons
    Scat cast crank and rods
    CRANE Retro HYD Roller cam #119841
    BBC 1.5"dia springs
    Canfield 195cc / 65cc heads
    Victor JR
    Holley #4777 650 DP
    5gallon fuel cell
    140 mallory fuel pump
    allthis has gone low 11's
    Kricka likes this.
  8. Justin79maro
    Justin79maro Veteran Member
    273
    11
    Jan 15, 2015
    Bonne terre, missouri
    Year and weight
    1979 camaro
    Stock weight
    Engine
    385
    Bored .040
    Hyp. Pistons
    5.7 rods
    Worked vortec heads
    Comp cam xtreme camshaft
    750 slayer
    External balance
    440hp/454tq @flywheel
    Exhaust
    Jegs 1 5/8 long tubes
    3" collector
    3" Axel dumps w/ dynomax bullets
    Rear
    3.42 gears from 79 z28
    Suspension
    Sfc
    Lakewood slapped bars
    Stock Springs
    Oem front shocks
    Rear air shocks
    Transmission
    Th350
    B&m shift kit stage 2
    Harden sprag
    B&m nitrous hole shot 3,000 stall
    Times
    1.81 60'
    7.98 @87 with this motor (fuel problem)
    1.88 60'
    7.97 @88 with old motor
  9. redriderjf87
    redriderjf87 Veteran Member
    139
    13
    Jan 23, 2016
    Quad Cities, IL
    1981 Z-28
    Stock weight
    Engine
    355 CI ('69 4 bolt block)
    Sealed Power H345NCP plat top pistons
    10:1 compreesion
    Dart SHP 180cc aluminum heads
    Comp Extreme Energy XR276HR hyd roller cam
    Edelbrock Performer RPM Air Gap intake
    FiTech 4bbl TBI
    MSD Pro-billet HEI (controls EFI timing)
    Exhaust
    Long tubes (don't remember diameter)
    True duals 2.5"
    Pipes Race Pro mufflers / cutouts past collector
    Transmission
    Mechanical clutch
    Tremec TKO-600 5-speed (0.64 OD, Hurst Drivelines kit)
    2,000 rpm @ 60 mph
    Rear
    GM 10 bolt
    4.11 rear gear
    Suspension
    Stock Springs
    Stock front shocks
    Rear air shocks
    Welded subframe connectors
    Caltrac style traction bars
    Wheels/tires
    225 / 245 mm staggered street radials
    Centerline aluminum wheels (15" I think)
    Drag times
    Never raced or dyno'd the car yet in this config. With the old setup the best I had was 13.9 @ 100. I am hoping I can get in the lower 13s with this setup and a little practice launching (and maybe some better tires).
  10. optimusprimerib
    optimusprimerib Member
    62
    9
    Sep 12, 2001
    Kalispell, MT, USA
    Year weight
    1973
    3400#
    Dyno numbers
    488 ft/lb @4800 & 448 HP @~5500
    Engine
    383 CI
    11.1:1 compression
    GM Fast Burn heads 2.00"int/1.55"exh
    GM Vortec Dual Plane
    Holley HP 750
    Edelbrock 2201 cam
    1.5 retro rollers
    Exhaust
    Dynatech MM Headers (stepped)1 3/4 - 1 7/8" primary to a 3" collector
    Full Bore mufflers
    Pypes Performance X-pipe
    3:55 Eaton posi and GM 10 bolt stock rear
    batt in trunk
    March serpentine pulleys/dual 10" elec fans
    Suspension
    Stock
    Transmission
    "Stage 2" TH350 (unknown builder)
    Hughes 3000 stall converter
    All kinds of messed up, but it runs!
