Your preferred battery for drag racing?
OldCamaroNut
948
Rancocas Woods, NJ
What's the best choice? I'm not running an alternator and will be recharging it between rounds. Also, my motor doesn't have a ground strap to the firewall because I didn't think I needed it with solid mounts. Am I right? Thanks in advance.
mrdragster1970
All drag cars should have a 16V battery now a days.
It makes zero sense not to. All the electronics work better at full power.
You get a lot more stored energy for those emergency situations.
It would suck to lose a round or race due to hot lapping and going up there with 11 volts, instead of 15.
Listen to me on this, get a 16V, do it right, do it once.
I have both turbo start, and powermaster, both of been perfect.
I just switched to a deep cycle last year, and so far, so good.
Oh yea, always ground the engine to the battery, I don't care what we did in the past.
There is a lot less garbage in the system when the engine is directly grounded to the battery.
Mike N
3,069
Spencerport, NY.
Napa 850 CCA battery. The biggest thing they had. I also run an alternator, and have redundant grounds all over, even with solid mounts.
mrdragster1970
That's not what he asked, you run an alternator,
and that is definitely not the best choice for drag racing.
The best choice is an actual racing battery that has a special case,
and internal supports for all the vibration & forces applied during a run.
Some cheap battery for grandma's car is not even close.
Yes, that's what I ran in the beginning, but he didn't ask that.
fast72
100
Sacramento, Ca
Sears DieHard Platinum cannot be beat...I use to run the optimas and will not go back to them. The Platinum's are really an odyssey battery and is made of pure lead...Awesome but weigh in at about 60 lbs a piece. 930 cca
TNT
1,004
Owego NY
The AGM stuff is nice. Light weight and they work well. I have the braille 21 lb. battery. It replaced my 43 lb optima. They also make a nice little 10 amp charger that works good.
driftwood
2,026
07882, NJ
I have heard/read that the Braille's are acually made by Deka. They look identical when side by side. Only difference is the Deka line is maybe half the cost of brailles.
