Z28 fender emblem placement
Discussion in '1970 - 1973 Specific' started by Double J, Apr 12, 2017.
  1. Double J
    Double J Veteran Member
    411
    15
    Jan 23, 2008
    Michigan
    All,
    I've used the search function and came up with conflicting info on Z28 fender emblem placement. Who has the dimensions for the holes, I've seen the assembly manual and it's confusing as sh*t.
    Thanks
  2. jlsug
    jlsug Veteran Member
    305
    21
    Apr 10, 2012
    iowa
    m pozzi, Feb 6, 2006
    This is the measurements I got from a pair of original 71Z28 fenders.
    From the body line down is 1 7/8"
    All measurements are taken from the aft edge of the fender inline with the holes.
    LH from the edge to the first hole = 5 3/8" the next hole should be around 8" from the edge, but you can figure it out because you've already got the first hole.
    RH from the edge to the first hole = 6 3/8" the next hole should be around 9" from the edge.
    Double J likes this.
  3. stafs05
    448
    29
    Dec 26, 2007
    chicago,IL
    Hello if you want PM with your phone number, I have both sides of fenders sections from a 1973 Z I have. I will send pictures to you
  4. COPO
    19,624
    1,707
    Lots of luck with this one.
