Z28 hood springs for 4" cowl fiberglass hood
Discussion in 'Body Restoration' started by Dave Taylor, Oct 12, 2021.
  1. Dave Taylor
    Dave Taylor Member
    34
    Jul 28, 2021
    As I been out of the Camaro world a bit, I am repairing and updating a 81 z28 but it has a 4" fiberglass cowl hood, and I have a new set of high tension springs but they wont hold it up, is there a fix for this to keep the hood.
  2. Ratty_81
    Ratty_81 Veteran Member
    215
    119
    Nov 13, 2020
    I would take some measurements of the stock and lightweight springs then get on mcmaster-carr and try to find something in between.
  3. Zspoiler
    Zspoiler Veteran Member
    4,083
    470
    May 6, 2012
    Federal Way, Washington
    What brand of fiberglass hood? I have a Glastek " 6" cowl hood and I use a set of their springs that work .So I would talk to company whose spring you have.
  4. Dave Taylor
    Dave Taylor Member
    34
    Jul 28, 2021
    i dont know who made the hood all i know is its a 4" fiberglass cowl hood
  5. Zspoiler
    4,083
    470
    May 6, 2012
    Do you have a picture ? Especially underneath.
  6. Dave Taylor
    Dave Taylor Member
    34
    Jul 28, 2021
    here is the hood
  7. Knuckle Dragger
    16,513
    2,840
    Nov 2, 2002
    Waddell AZ
    I had the same issue on my Nova. I ran a secondary spring inside the first spring. I got them at ACE I think.
  8. Zspoiler
    4,083
    470
    May 6, 2012
    Maybe the Glastek hood spring would work on yours Since my 6" cowl hood is heavier image2.jpg
  9. G72Zed
    G72Zed Veteran Member
    3,131
    1,583
    Sep 8, 2015
    On my first Camaro that had a 4" fibreglass hood, sometimes the hood would close, all I did was drill a small hole in one of the hood hinges when it was up, and used an old trimmed door pin, no need for a prop rod, or strong springs that liked to makes hairlines stress cracks.
    Then if ever at a race track, or car show, and someone wants to close the hood, use a pencil or plastic pen case, instead of the steel pin, at least they will not crack the hood not knowing the pin is in the hinge.
    Then you give them a "crack" for touching your car LOL.
    MChamp and carhead22000 like this.
  10. krabben1
    8,262
    76
    May 16, 2007
    ( . Y . )Delco
    VFN has the springs.
