Z28 valve covers, something is off here
Discussion in 'Original Drivetrain Topic' started by Eliminator SS, Apr 30, 2020.
  1. Eliminator SS
    Eliminator SS Veteran Member Lifetime Gold Member
    2,945
    Nov 14, 2002
    South East, Nebraska
    Guys I picked these up the other day along with an original 302 air filter assembly. As with most stuff I seem to buy online as of late the sellers seem to take very directed images to keep the flaws from being questioned. But these go a bit farther than that. They almost look fake. Look at the breather ports. Not only are there no baffles, the ports look like they are deformed from a copy of a real one that still had the baffle in it? They don't appear to be blasted, it's like they are raw fresh castings and not really good ones. But I'm looking for opinions before I call the seller out. 20200430_102801.jpg 20200430_102738.jpg 20200430_102721.jpg 20200430_102717.jpg 20200430_102709.jpg 20200430_102656.jpg 20200430_102801.jpg 20200430_102738.jpg 20200430_102721.jpg 20200430_102717.jpg 20200430_102709.jpg 20200430_102656.jpg
  2. l16pilot
    2,123
    279
    Dec 13, 2004
    Hurlock, MD, USA
    Mike - honestly, they look like a set of used originals that had the baffles removed, were cleaned, (lightly bead blasted) and just did not have the baffles re-installed. Just my opinion, but if the seller represented these with the baffles or used words that would indicate the baffles were not missing, Yeah, I'd go back and ask for a refund...at least on the valve covers.
  3. Eliminator SS
    2,945
    Nov 14, 2002
    I paid $125 for them so I'm not out much just feel like the baffles need to be in there before being used. Can the baffles be purchased separately?
  4. flht99b
    flht99b Veteran Member
    836
    274
    Nov 28, 2014
    Knoxville, TN
    I've never seen the OEM baffles for sale although I can't say I ever looked for them. You'll have a hard time attaching them even if you found a pair of baffles. At $125 for the pair, you got what you paid for. These covers that are not late model repo's in good condition regularly sell for well over $200 and the covers without the cast in drippers command much more.
    Eliminator SS likes this.
  5. 70lt1z28
    4,573
    1,143
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Maybe the baffles from the stamped steel covers can be used? Easier and cheaper to find.
  6. 72'z'steve
    72'z'steve Veteran Member
    1,807
    752
    Oct 15, 2000
    waukesha wi usa
    I remember dimpling or removing baffles back in the day for roller rocker clearance but usually the drippers needed help too. I remember using rubber push it "baffle grommets" from the speed shop but they were a little big for the hole [this was the 80's and the cheap transdapt chrome covers didn't have baffles ] that was the fix for those.been 35 years bit foggy but I guess you could use those "baffles to keep the oil sucking/splattering to a minimum! Later Steve!!
  7. COPO
    21,380
    2,795
    Find a junk set and JB the baffles in. I don’t understand why some knuckle head would remove them to blast them.
  8. Eliminator SS
    2,945
    Nov 14, 2002
    I would agree. I think I still did just fine. They are in pretty nice condition overal. Just wish they had the baffles in them. It appears based on the numbers in them that they are in fact 1970 valve covers. So I think I'll just let the baffle issue go. I got my money's worth.
  9. Gary S
    24,235
    1,699
    The casting numbers inside will tell you what year or years they are. There were about 4 or 5 different versions of these covers with different numbers. There are posts here on Nasty with pictures and those numbers to identify them.
  10. COPO
    21,380
    2,795
    If they are 1970 Z28 LT1 or 70 sYc Nova or 70 LT1 Vette Covers then they will have 3 part #’s inside.
    P - 3932417 - LH C-1 CBC
    P - 3965543 - LH
    P - 3965544 - RH
    1969 Corvette & Z28:
    Cast. #
    P-3932418
    Without drippers, "cutouts" are 3" long
    Late 1969 and 1970 Z28 & 1970 Corvette
    Cast #
    P-3932417-LH C-1 CBC
    P-3965543-LH
    P-3965544-RH
    Drippers are 11/16" wide @ bottom, 3/4" in height, "cutouts" are 3" long
    These covers were possibly used on very late 69 Z28's made in Oct. & Nov. 1969.
    1971-1972 Corvette & Z28:
    Cast. #
    3989005 LH
    3965542 RH
    Oil cap hole is round for black rubber oil cap, "cutouts" are 3" long
    1973-1977 Corvette & 1973-1974 Z28: Cast. #
    P-3965543 LH CBC
    P-3965544 RH
    Drippers are 5/8" wide, 5/8" in height, "cutouts" are 3 9/16" and 5" long.
