ZZ4 HEI w/Pertronix D72000
Discussion in 'Engine Topic' started by PHROG, Sep 14, 2021.
  1. PHROG
    PHROG New Member
    14
    Sep 27, 2017
    Amarillo Texas
    Has anyone here tried a Pertronix D72000 in the OEM HEI used in the ZZ4?
  2. CorkyE
    11,381
    905
    I had one of those modules in a Mallory distributor (stock type), it went south in short order. YMMV
  3. Lowend
    16,465
    1,262
    Mar 25, 1999
    San Jose, CA, USA
    I'm not sure there's a lot of benefit to the module swap on that distributor.
    What are you trying to accomplish?
  4. PHROG
    PHROG New Member
    14
    Sep 27, 2017
    Amarillo Texas
    Pertronix claims the module will give multiple spark at lower RPM like a CD box. Ultimate goal is the best possible fuel mileage in a 34 Chevy coupe that cruises at 2500 rpm/75 mph.
  5. Lowend
    16,465
    1,262
    Mar 25, 1999
    San Jose, CA, USA
    I seriously doubt you could do an effective multi-spark with a unit that small. Petronix is known for enthusiastic advertising on its ignition products.
    If I was doing an HEI build out - this is what I would use
    https://www.holley.com/products/ign...butor_accessories/conversion_kits/parts/85001
    The HEI's biggest weakness is heat buildup. Moving the coil off the cap deals with that.
    That said, for most street motor's a properly tuned HEI (with a good curve kit) is more than up to the task. You'll probably find more efficiency with dyno tuning than part-swapping
    MChamp likes this.
  6. sandlapper
    sandlapper Veteran Member
    795
    291
    Oct 9, 2020
    SE CSA
  7. Lowend
    16,465
    1,262
    Mar 25, 1999
    San Jose, CA, USA
    $12 solution to a $400 problem, I like it.
    We even have a coupon code for Rock
    5% Discount Code: 266E10C98D2D13
    Expires: December 12, 2021
    Please enter this code in the ‘How Did You Hear About Us’ box to receive the discount. Please enter ONLY the discount code, no other words or numbers. All orders are placed online and the discount code must be entered before an order is submitted to receive the discount.
    sandlapper likes this.
  8. biker
    biker Veteran Member
    3,803
    1,797
    Dec 7, 2014
    If I didn't live in the land of brokerage fees and half price money, I'd buy one of these today: https://progressionignition.com/
    Get the small cap one with separate coil, dial in your timing specs and go.
    1320feet, camaro71/holland and MChamp like this.
  9. Lowend
    16,465
    1,262
    Mar 25, 1999
    San Jose, CA, USA
    oooohh I like that
  10. MChamp
    MChamp Veteran Member
    221
    61
    Jun 6, 2021
    north carolina
    Oh heck yeah, now that's what Santa needs!
