I read White81Z's posting about his time capsule...which prompted me to solicit the opinions of the forum on my own time capsule....it is a 46k original 70 Sport Coupe, 350, 2bbl, auto, air, Van Nuys built, Shadow Gray with tan/saddle standard interior. It still wears the original paint, which is burned through from the sun on the upper surfaces, appears to be spray-bombed gray primer as a cover up....which has also burned through in many areas from the sun.
Here's my question to the membership.....I have considered using this car to "re-body" my 2nd 70 Z28, which was converted into a drag car in 1974...hence there isn't much left original except the trim tag, rear, sway bar brackets, front a-arm bumpers and the gas pedal. The body has been butchered and the original doors and front sheetmetal are long gone. My reasoning is that the CA car retains 100% of it's original sheetmetal, as assembled by Fisher/GM. Replacing the sheetmetal on my Z, quarters, inner/outer wheelhouses, trunk floor pass compartment floor, rear panel/valance), means that a large percentage of the sheetmetal is Taiwanese. Isn't a "rebody" nothing more than a 100% sheetmetal replacement?
Right now, I am using it as a 3D assembly manual to finish my 1st Z28, (RS, Mulsanne Blue), but once that is finished....I'll need to start making some decisions and I am really interested in everyone's opinions.....good, bad and indifferent are all welcome.
