bricejones41
i had fuel pressure issues earlier, i just went to electric fuel pump, this was my first time driving it with the new holley 750 carb, and no fuel supply issues. the first thing is, 1 the port vacuum, where i plug the vacuum advance has like 10lbs of vacuum at idle, then when i hit the gas it drops to 0 then goes back up to like 20 (i hooked that hose to a vacuum gauge instead of the distributor to find those numbers) which causes an AWFUL studer when i hit it, so i tried driving it with that just plugged, and 2 when i hit it from a standstill it acts as if there is a rev limiter at 4k. 3 i took the air filter off and revved it and the vacuum secondaries of the carb weren't even opening. 4 lastly there were fumes/steam coming out of the oil filler cap when i opened it, the fumes smelt like gas, but faint enough that i might have been smelling the carb.
sorry to ask so much, but in your answers just put the number of the broblem you are refering to, just to make things simpler
here are some specs of the engine
scat strocker kit with cast 9000 series crank, forged pistons and i beam rods
the cam is a crower 234 int./246 exh at .050 Lift .497/.502
the heads are dart aluminum shp 200cc
it measured out to 10.4:1 cr
elderbrock performer intake
turbo 350 tranny,3200 stall
holley 750
stock ignition with new cap and rotor
holley 750
