74 Camaro,lots of new work done.
  • Thread starter Rich Schmidt
Rich Schmidt
4,285
Denville NJ
Check it out at this tread
http://www.nastyz28.com/forum/showthread.php?t=212432
It is now running great. I will be including a Herb Adams sway bar for the front,and a set of bolt in sub frame connectors(the car already has new body mount bushings). It starts up at the tap of the key. I need to put the interior back together,and it will have a newer rug out of one of my other cars in it. This car is a good project for somebody looking for a car that they can drive while doing the bodywork on and making nice. It has some home done patches on the floors and rear rails,all are welded in. It has a fair amount of plastic on it,the fenders look o.k. with some patches that arent even filled over yet. The doors look decent. It looks like it could use 1/4 skins the rest of the body is pretty good. Its a black interior,but some of the parts were dyed black.
The engine is a HO 305 from the early 80's with a lot of mild performance work done. Its probably close to 300 hp. It was a low miles complete engine when installed. I took the heads of,had them rebuilt with a 3 angle valve job back cut valves(not the home done ones in the tread),I bowl blended them,added new Z/28 springs and retainers. It has a mild speed pro cam,.420/.442 lift 204/214 duration,new lifters(of course) and double roller chain. A performer intake and brand new 600 Edelbrock carb with electric choke.It has a new Interstate battery,with new tray and hold down,new cables,new power lead tothe fuse box with 80 amp circuit breaker instead of the fuseable link wire mess that used to go to the starter. The headers are new,the exhaust is 2" duals with turbo mufflers and is quiet with a deep rumble.
I have nevwer driven the car,but it stops and steers fine in my driveway,and can be test driven before you buy it. The tires have no miles on them,all the engine work has no miles either. I dont think it has a posi rear.
$2000 OBO.
Rich Schmidt
4,285
Denville NJ
If you dont have cash,I need a few items for my current project that you can buy with a credit card in trade for the car. One of the items is the complete rear floor pan/frame rail assembly for the 2nd gens. It sells for about $1500. The other is the one piece floor pan minus the braces thats sells for about $350.
I would also consider trades for a reasonably solid 70-73 bare shell. No subframe,doors ect. Let me know what you have and we can work it into the trade.
SpecZ28
54
NY
can you take more pics of the bad spots...I wasnt looking for an auto but I like 74s and its cheap
