64BELOW
hello, new here, have a few questions, need help with a 350 small block chevy, pulled from junk yard, i pulled the engine out of a 1970 brookwood station wagon, it is an orig, 350 turbofire 300 horse engine 4 bold main, 195/150.64cc chambers, it is complete from air cleaner to oilpan and water pump to flywheel,the wagon had a 350 auto and a bad a$$ rearend, but im gonna try and put this engine in my 1964 chevy biscayne, the biscayne has a 283, 3 speed on the tree, the wagon had 69,000 orig miles, removed valve covers, oil pan, and intake, everything looks great, no sludge, no carbon, motor turns over great, my machine shop said dont screw with it, the engine is all orig, it should run great, i dont want to rebuild it if i dont have to, would like to drop it in the 64 and roll out, i have a hei distibutor from a newer chevy truck that had a goodwrench 350 in it, should i stick with the orig points, or try and convert it to hei? the engine has the orig exhaust ram horn exhaust manifolds with the 2 inch outlets,i have a set of headers should i leave the exhaust alone? i dont want the biscayne to be to loud or it might scare off the mustangs, you know wild horses are spooked by loud chevrolets,i want the biscayne to look old and slow, any help? any ideas, with out to much mods, the engine is an all orig 350 turbofire, i would like to keep it that way as much as possible just in case i sell the car after im done with it and try and beat up on some ford guys, if the engine runs good i want to keep it in the car, if not then it will go and be rebuilt, any help would be great, thanks
